Plug Wires on 2.5L - JeepForum.com
post #1 of 4 Old 07-11-2010, 08:57 AM Thread Starter
ReformedTJr
Plug Wires on 2.5L
Just replaced the plug wires on my 4cyl and may have mixed two of them up at the distributor.
Does this matter and can anyone tell me (or maybe have a photo of) the proper configuration?
1997 TJ - My Second One
No mods yet, just lots of hope and ambition.
ReformedTJr is offline
post #2 of 4 Old 07-11-2010, 09:08 AM
wozz
Yes it matters. If you got two or more wires mixed up your firing order will be off. This means that a cylinder could be firing when it is not supposed too. Have you ran it yet? If so I bet it ran rough and threw a code.
wozz is offline
post #3 of 4 Old 07-11-2010, 09:12 AM Thread Starter
ReformedTJr
No, not going to run it until I make sure I have it set right. Did one wire at a time, but one of them slipped off when I wasn't looking so I just want to make sure I set it back up right.
post #4 of 4 Old 07-11-2010, 10:28 AM Thread Starter
ReformedTJr
OK, found that the firing order is 1342, and that the number 2 cyl wire is placed at the position closest to the block
Ran it for a couple of minutes and it sounds smooth with no error codes.
2.5 , tj , wrangler , plug , wires , distributor , diagram
Plug Wires?? Wildcat83 TJ Wrangler Technical Forum 11 11-25-2009 06:22 PM
Plug wires vbguru12000 TJ Wrangler Technical Forum 3 09-26-2007 12:31 PM
Plug Wires JeeperAbe TJ Wrangler Technical Forum 3 01-29-2007 04:22 PM
HEI plug wires? slimpickens YJ Wrangler Technical Forum 2 09-02-2005 06:43 PM
Are 7mm plug wires ok? drew2000 YJ Wrangler Technical Forum 2 02-15-2004 01:55 PM
