Plug and Play? - JeepForum.com
post #1 of 7 Old 11-21-2010, 08:40 PM Thread Starter
Waldo02
Plug and Play?
I'm looking at putting a new stereo in my Jeep. I saw Quadratec has a 'plug and play' wiring harness. I was wondering:
A) is it as easy as they make it sound?
B) is it worth 134 f'n bucks or can it be found cheaper elsewhere?
Waldo02 is offline
post #2 of 7 Old 11-21-2010, 09:09 PM
wushaw
Rockin jeep
wushaw's Avatar
Why no it's not as easy as it sounds, there are fasteners and panels that will have to be removed for the R&R of the radio.
wushaw is offline
post #3 of 7 Old 11-21-2010, 09:13 PM
Dmcastino
Its a pretty easy task really, but there's no reason to pay that much. Check out crutchfield, those harnesses are usually 20 bucks or so.
Dave
IndyORV member
My build thread:
Dmcastino is offline
post #4 of 7 Old 11-21-2010, 09:31 PM
Dean7276
I put in a Kenwood from Crutchfield for $139 and they give you the harness and faceplate adapter that fits perfectly in the Jeep. Easiest install I've ever done. Free shipping too.
Dean7276 is offline
post #5 of 7 Old 11-21-2010, 09:45 PM
wrangler04
1) things are usually never as easy as they sound
2) thats way over priced. check crutchfield or somewhere els. They're usually cheaper
wrangler04 is offline
post #6 of 7 Old 11-21-2010, 10:13 PM
djt283
djt283's Avatar
I'm not sure exactly what you were looking at but no harness costs that much. It's probably a head unit with the harness, and depending on which unit it could be a fair price. The harness alone is never needed, unless you don't want to splice your factory wiring (under warranty, don't know how, etc.). Every unit should come with a harness that fits it and then you simply splice the corresponding wires to the ones in the factory unit. Buying the vehicle-specific harness only saves you about 20 minutes on the install (if that).
But to answer your question...and I'm still assuming you're talking about the head unit:
1) Unclip and remove the defroster vent at the bottom of the windshield
2) Remove center dash piece by removing two screws on top and one behind ashtray
3) Remove factory unit (there is an anti-theft bracket connected to the firewall in two spots)
4) Install any needed adapter to make the new unit fit (it's a different size)
5) The wiring harness (vehicle-specific) simply attaches to the female end that came out of the stock unit and plugs into the new unit.
6) Slide it in
There are some more steps, but that's basically what you're in for.
djt283 is offline
post #7 of 7 Old 11-22-2010, 12:10 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Crutchfield X-mas specials coming later this week.
TheBoogieman is offline
radio , stereo , wiring harness
Plug and play? Waldo02 Wrangler General Discussion 4 11-23-2010 05:40 PM
Gauges plug & play Classicboss1 YJ Wrangler Technical Forum 1 06-22-2009 09:10 PM
2.5 to 4.0 Plug & Play? LandoCommando TJ Wrangler Technical Forum 9 06-17-2008 05:24 PM
Plug and Play chip for '06 GoldenEagle06 TJ Wrangler Technical Forum 12 04-18-2008 08:15 AM
plug-n-play? raysnutt18 YJ Wrangler Technical Forum 5 07-09-2007 07:38 PM
