Quantcast Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift
Old 09-13-2009, 11:43 PM   #1
jondotcom
Would you experts out there let me know if I'm forgetting anything on this setup... trying to keep the $$ spend to a minimum.
2004 Wrangler Unlimited Auto, 44 rear with tracklock, 30 front with aussie locker, 2" Budget Spacer lift with new 32x11.5x15s BFG KMs on factory alloys, longer rear shocks. I learned the hard way about disconnecting without longer bump stops (bent my fender and "siped" my tires), so I have some extension on the way.
I want to add a tad more body clearance as well, so I'm planning on a 1" body lift. I'm looking at the M.O.R.E. and performance accessories line, and am also considering a 1" JKS motor mount lift. If I do the motor and body it avoids having to move the fan shroud, and it also gets that oil pan away from the rocks.
Am I forgetting anything if I do this (like when I forgot about bump stops). Is raising the motor going to screw up my driveline angles, etc?
Advice appreciated. Thx
jondotcom is offline   Reply With Quote
Old 09-14-2009, 03:12 AM   #2
Mires
Sorry man but I can't provide much input on the subject. Just thought you deserved a free bump Good luck with everything and don't forget to post pics when you're all done!
www.giftboxesbymail.com - For all your gift giving needs!
Wanting to be someone else is a waste of who you are - Kurt Cobain
Mires is offline   Reply With Quote
Old 09-14-2009, 03:59 AM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Performance Accessories is a very good BL for $100 or less.I always use them.The BL and MML won't change anything that will cause more problems.Together they keep you from moving the fan shroud or using the t case shifter bracket.I did the BL on my latest Jeep and then got a MML because it was cheap and didn't want to drop my t case with my 3" lift.Unless you want the 1" oil pan clearance,there's no reason for a MML.The fan shroud takes 10 minutes to fix.
TheBoogieman is offline   Reply With Quote
Old 03-05-2010, 07:31 PM   #4
dougiefresh131
i'm relatively new to all of this, but i was considering getting a 1 inch BL. I am reading about having to move the fan shroud. What is this and why is it necessary? Is there anything more I would have to do/modify if I installed a 1in BL?
dougiefresh131 is offline   Reply With Quote
Old 03-05-2010, 08:16 PM   #5
TJDaveX
black X
TJDaveX's Avatar
Motor on frame, radiator on body. Body lift will raise radiator, but motor and fan stay where it's at. A MML will raise the front of your engine 1" and make the fan match the shroud again. Plus it will tilt your tailshaft down a bit and help your driveline angles for the cheapy lifts.............LIKE MINE!
TJDaveX is offline   Reply With Quote
Old 03-05-2010, 09:41 PM   #6
dougiefresh131
what's the deal with modifying the fan shroud stuff? is that so you dont have to buy a MML?
Old 03-05-2010, 11:32 PM   #7
mudb8
want it rite or rite now?
mudb8's Avatar
If you value your time and sanity, the MML is easier and more cost effective in the end than messing with the shroud relocation brackets, not to mention the other benifits the MML provides.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 03-06-2010, 12:15 AM   #8
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
X's 2! The MML took me a whole 45 minutes to pay for, drive home and install! I messed with that fan shroud for 2 hours before I went and bought the MML...
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 03-06-2010, 12:20 AM   #9
RogueSpear2023
JF is my second home.
Agreed MML is much better and much easier on time and frustration, it's an easy install and runs about $60 from Rough Country, it's the same one JKS sells except the blocks aren't anodized red.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Old 03-06-2010, 12:45 AM   #10
mudb8
mudb8's Avatar
Originally Posted by chilipalmer View Post
x's 2! The mml took me a whole 45 minutes to pay for, drive home and install! I messed with that fan shroud for 2 hours before i went and bought the mml...
lol,......
Old 03-06-2010, 03:43 PM   #11
SeattleTJ
You might have to modify your console and shifter after these mods. I had to remove the foam rubber pad on the stick shift that is under the shift boot, and then had to move the center console back about an inch in order to keep the shifter from popping out of 2nd gear and 4th gear. I did the Rough Country motor mount lift, body lift, and the suspension lift.
1999 TJ, 4.0, AX15 5-Speed, NP231, Dana 30 open 3.73, Dana 35 Detroit Locker 3.73, Rough Country 2.5" suspension lift, 1.25" body lift, 2.2 shocks/stabilizer, JKS Discos, 33 x 12.50 Mickey Thompson MTZ tires on 15 x 8.5 MT Classics
SeattleTJ is offline   Reply With Quote
Glock Forum
