please help me! rolled my tj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > please help me! rolled my tj
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-19-2007, 10:16 AM   #1
tjlover03
i rolled my jeep this weekend into a creek after hitting some ice. it was not a good weekend. anyways once we got in up out the creek i turned the key just for a slight second and it didnt even have time to turnover and i stopped thinking i better wait to the next morning to check the spark plugs. so i took out four spark plugs and the first three were dry but the fourth i pulled had oil on it. and i took off the air filter at the throttle body and there was oil ang gas in it. so what do i need to do to the engine or clean in order to beable to start it up again. i dont want anything to happen to it. and if anyone is selling a window and frame or a hood for a tj let me know thanks joshua.
tjlover03 is offline   Reply With Quote
Unread 02-19-2007, 10:20 AM   #2
1BadJeepX06
Drain oil... Pull intake manifold and everything.. Throttle body will need a good cleaning (get ya some seafoam spray).. Throw new Champion plugs in it (might as well, it needs new ones every 30,000 anyway)... Air filter is prolly gunked up (snatch a new one). As for the windshield and hood, try e-bay.. there will be plenty of stuff on there to choose from..
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline   Reply With Quote
Unread 02-19-2007, 10:21 AM   #3
mrblaine
mrblaine's Avatar
DH
Why on earth would you pull the intake?
mrblaine is offline   Reply With Quote
Unread 02-19-2007, 10:23 AM   #4
1BadJeepX06
Gasoline and oil finding there way in there depending on how long it was upside down.. At least from my understanding.. Had to pull the one off of an old samurai after we rolled it in high school.
DH
Unread 02-19-2007, 10:28 AM   #5
tjlover03
anything else i should try? what about after i do all that should i start it without the spark plugs first or what?
Unread 02-19-2007, 10:29 AM   #6
1BadJeepX06
It won't start without plugs...
DH
Unread 02-19-2007, 10:50 AM   #7
97_tj
i think he ment crank it over without plugs in it to make sure everything is out of the cylinders
97_tj is offline   Reply With Quote
Unread 02-19-2007, 10:50 AM   #8
tjlover03
yes i know it wont start without plugs ijust want to make sure they are clear before i put in the plugs ya know?
Unread 02-19-2007, 10:50 AM   #9
97_tj
double post
Unread 02-19-2007, 10:51 AM   #10
tjlover03
Unread 02-19-2007, 10:58 AM   #11
1BadJeepX06
Yes, by all means do that... Clean the inside of the cylinders real well before you throw new plugs in..
DH
Unread 02-19-2007, 11:30 AM   #12
Pyroteknik701
Thats kind of what i do to my jet skis. When they have water, oil, or extra gas built up in the cylinders, i just take the plugs out and crank it over a few times and it shoots the extra fluids. Dont know how this would work on a Jeep but i guess its worth a try
2.25" budget boost, 1" Performance Accessories Body Lift, flowmaster 40 series, kenwood stero system, new front and rear bumpers,dual tops, and 33"x12.5" BFG All Terrains, on unique black steelies, Rubicon Express Steering Stabilizer
Pyroteknik701 is offline   Reply With Quote
Unread 02-19-2007, 12:14 PM   #13
tommaho
Huh? You were serious about the intake pulling bit too?
What do you think happens in a roll that would warrant so much work?
[edit]
OP: Just eyeball your wiring, coolant, and fuel lines if you really crunched the body. If all is well: pull your plugs, crank the engine for about 5 seconds to clear the chamber of oil, put the plugs back in, check all your fluids, and keep on truckin.
Barring an electrical failure or breakage of some other critical part, it's really as simple as that.
[edit x2]
And take the time to clean up any spills.
Blue Ribbon Coalition | SIRA 4x4 |
tommaho is offline   Reply With Quote
Unread 02-19-2007, 02:41 PM   #14
1BadJeepX06
By cleaning the inside of the cylinders, I mean turn it over without plugs.. Does this not "clean them out"... Dont' get to techincal here with me guys.... And yes, the intake prolly needs some attention if he flipped "into a creek" like stated above.. I know I would check mine out if I "flipped into a creek"...
But who knows..
DH
Unread 02-19-2007, 03:18 PM   #15
j0nesy
pull the spark plugs and crak it over for a good bit ... enough to clear out the cylinders of oil and any debris.... put the plugs back in, crank it till it starts
standard procedure for a rollover
j0nesy is offline   Reply With Quote
