Please help me with my constant radiator problem! - JeepForum.com
post #1 of 18 Old 01-18-2012, 12:18 AM Thread Starter
Kev-ollllo
Hello everyone,
I have used all my knowledge, and almost three years later im here, asking for the help of all you knowledgeable jeepers. Okay so, three years ago my stock radiator went out so I bought a new one from Quadratec. I bought a $500 aluminum one. Six months later... it started to leak. I got it returned and replaced and had it professionally installed. Once again six months later it started to leak. I called took it to a radiator shop and they said the core was leaking so they "fixed it". Well a week later is started leaking again. For the third time i got a new one and installed it along with a brand new water pump... guess what!... six months later it started leaking again! I went back to a stock radiator and thought i was finished with this BS. The reason im asking for everyones help is because this radiator is now leaking and i am at a loss for words. Please help me...
Kev-ollllo is offline
post #2 of 18 Old 01-18-2012, 12:26 AM
wushaw
Rockin jeep
wushaw's Avatar
Where is it leaking from the radiators?
You may just have the radiator curse for awhile??? I have never seen or heard of so many issues with radiators.
Have you flushed the cooling system?
wushaw is offline
post #3 of 18 Old 01-18-2012, 12:31 AM
chitownEMT
My first question is, with each radiator, was it leaking from the same place or different places each time? My second question is, what do the people at the shop who did the installations say?
-98 Wrangler Sport Chili Pepper Red
|AX15|NV231|D35c Trac-Lok|2" BB|Bushwacker Pocket Flares|31x10.5 GY Duratracs|AR Outlaw II 15x8|Trektop NX|
In the long run men hit only what they aim at. Therefore, though they should fail immediately, they had better aim at something high.
- Thoreau
In the depths of winter, I finally learned that there was, within me, an invincible summer.
- Albert Camus
Disclaimer: The advice given on this forum is free; however, its value may be much less than you paid for it.
chitownEMT is offline
post #4 of 18 Old 01-18-2012, 12:33 AM Thread Starter
Kev-ollllo
On the aluminum radiators it was leaking from the bottom right corner if your looking at the front of the jeep. On the stock plastic one, its coming from the seams at the top. And yes i flushed it every time i put the new radiator on.
I hope i dont have a curse!
post #5 of 18 Old 01-18-2012, 12:34 AM
JPNinPA
How about "I'm going to get a refund and buy a stock OEM radiator like many will suggest."
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #6 of 18 Old 01-18-2012, 12:35 AM Thread Starter
Kev-ollllo
The people at the shop said the aluminum radiator could have developed a leak from bending the core or electrolysis.
post #7 of 18 Old 01-18-2012, 12:35 AM Thread Starter
Kev-ollllo
i have a stock one on there now.
post #8 of 18 Old 01-18-2012, 12:37 AM
chitownEMT
A brand new stock one? As in one from the dealer or an auto parts store?
- Thoreau
- Albert Camus
post #9 of 18 Old 01-18-2012, 12:38 AM
Eric1371
Could something be loose or tweaked, causing the mounting locations for the radiator to flex and damage it?
Semper fidelis.
Eric1371 is offline
post #10 of 18 Old 01-18-2012, 12:38 AM
wushaw
Rockin jeep
wushaw's Avatar
Well on the plastic radiators that is where all of em seem to go to leaking...yours just happen to go to leaking sonner than most do.
The aluminum units could have just been defective units.
You have had a bad run of radiators that is for sure.
wushaw is offline
post #11 of 18 Old 01-18-2012, 12:40 AM
wushaw
Rockin jeep
wushaw's Avatar
The grill supports the radiator, it would have to be broken.
wushaw is offline
post #12 of 18 Old 01-18-2012, 12:42 AM Thread Starter
Kev-ollllo
Yeah a brand new stock one from a jeep dealer.
I even added rubber grommets in between the mount and the radiator so cut down on vibration.
This makes me want to rip everything out and start over to create the perfect, leak free, jeep.
post #13 of 18 Old 01-18-2012, 12:44 AM
JPNinPA
Bending the core? How or Why? Was there a reason it would be bent?
JPNinPA is offline
post #14 of 18 Old 01-18-2012, 12:45 AM
wushaw
Rockin jeep
wushaw's Avatar
There are too many Jeeps runnin around without the issues your having.
It's just a run of bad luck, get the new one warrantied.
wushaw is offline
post #15 of 18 Old 01-18-2012, 12:47 AM
JPNinPA
What kind of radiator cap are you using. 18 Lb cap?
JPNinPA is offline
aluminum , leak , radiator , stock
Constant voltage problem MattJeep TJ Wrangler Technical Forum 6 12-05-2011 06:39 AM
Radiator problem reidtucker YJ Wrangler Technical Forum 2 12-01-2009 12:12 PM
radiator problem lilmike386 YJ Wrangler Technical Forum 3 08-29-2009 04:06 PM
3 row radiator problem k2snowboard YJ Wrangler Technical Forum 8 02-15-2006 09:27 AM
Weird engine problem, semi-constant revs. nix_toy TJ Wrangler Technical Forum 7 01-30-2005 03:10 AM
