Plasti dip inside tub - JeepForum.com
post #1 of 39 Old 05-21-2013, 09:55 PM Thread Starter
Bradleyselma
I was thinking about Plasti Dipping the inside of my tub for noise and to get rid of some rust that is under front side floorboards....has anyone tried this? If so how did it turn out??
Bradleyselma is offline
post #2 of 39 Old 05-21-2013, 10:38 PM
hustler905
How do you figure PlastiDip will fix rust?
hustler905 is offline
post #3 of 39 Old 05-21-2013, 10:41 PM
LJ_Cool
2003 WJ
well, it will get rid of the sight of the rust.
03 WJ Limited, 04 Overland
LJ_Cool is offline
post #4 of 39 Old 05-21-2013, 10:46 PM Thread Starter
Bradleyselma
That's what I was thinking I have carpet I'm going to put it back down I'm thinking more sound for radio and less road noise yet it is a jeep
Bradley
post #5 of 39 Old 05-22-2013, 01:36 AM
Davetha
Davetha's Avatar
I would think Plastidip would scratch up easily, and wear where your feet are. For sound dampening, carpet will probably be the best, truck bed liner might help a bit too.
Davetha is offline
post #6 of 39 Old 05-22-2013, 05:12 AM
bobjp
You can't paint over rust and expect good results. Plasti Dip will not hold up at all.
97 TJ sport.
bobjp is offline
post #7 of 39 Old 05-22-2013, 10:07 AM Thread Starter
Bradleyselma
You think I could take a biscuit grinder and brush rust off then hit it with a rattle can then plasti dip the tub then?
Bradley
post #8 of 39 Old 05-22-2013, 10:16 AM
Davetha
Davetha's Avatar
Yes, or a sander. You'll only need to hit it for a second, and then apply the spray paint.
Davetha is offline
post #9 of 39 Old 05-22-2013, 10:18 AM Thread Starter
Bradleyselma
That's what I was thinking but just wanted some opinions my thinking is if I don't like plati dip I can peel it off
Bradley
post #10 of 39 Old 05-22-2013, 10:24 AM
LJ_Cool
2003 WJ
Depends on how thick you plasti cote it, the rubber is great for sprayed on thin coats, but I think some other bed liner type product would be more durable, especially when put on over your attempt to "knock the rust out"
LJ_Cool is offline
post #11 of 39 Old 05-22-2013, 10:26 AM Thread Starter
Bradleyselma
What would you guys recommend if i was to bed liner it?
Bradley
post #12 of 39 Old 05-22-2013, 01:15 PM
roosr
Monstaliner - http://monstaliner.com/
Line-X - http://www.linex.com/
LizardSkin - http://www.lizardskin.com/
Herculiner - http://www.herculiner.com/
Just as starters. Might be much better, and definitly more durable than plastidip
JEEP = Just Empty Every Pocket!!!
roosr is offline
post #13 of 39 Old 05-22-2013, 01:44 PM
ORfishinjeep
Al's Liner has a kit with spray gun for bed liner and they also have a material to spray over the top for noise and heat reduction.
http://www.alsliner.com/alsHNR
This is the direction I am leaning to do my inside tub.
ORfishinjeep is offline
post #14 of 39 Old 05-22-2013, 01:52 PM Thread Starter
Bradleyselma
Ok I'm not wanting to crack out too much cash
Bradley
post #15 of 39 Old 05-22-2013, 02:10 PM
nmtj
Plasti dip will not last if anything comes into contact with it. Sprayed the backseat area and it started coming off in a few weeks
nmtj is offline
floor board , noise , plasti-dip , rust , tub
