-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Plasti dip inside tub (http://www.jeepforum.com/forum/f9/plasti-dip-inside-tub-1526631/)
Bradleyselma 05-21-2013 10:55 PM
I was thinking about Plasti Dipping the inside of my tub for noise and to get rid of some rust that is under front side floorboards....has anyone tried this? If so how did it turn out??
hustler905 05-21-2013 11:38 PM
How do you figure PlastiDip will fix rust?
LJ_Cool 05-21-2013 11:41 PM
well, it will get rid of the sight of the rust.
Bradleyselma 05-21-2013 11:46 PM
That's what I was thinking I have carpet I'm going to put it back down I'm thinking more sound for radio and less road noise yet it is a jeep
Davetha 05-22-2013 02:36 AM
I would think Plastidip would scratch up easily, and wear where your feet are. For sound dampening, carpet will probably be the best, truck bed liner might help a bit too.
bobjp 05-22-2013 06:12 AM
You can't paint over rust and expect good results. Plasti Dip will not hold up at all.
Bradleyselma 05-22-2013 11:07 AM
You think I could take a biscuit grinder and brush rust off then hit it with a rattle can then plasti dip the tub then?
Davetha 05-22-2013 11:16 AM
Yes, or a sander. You'll only need to hit it for a second, and then apply the spray paint.
Bradleyselma 05-22-2013 11:18 AM
That's what I was thinking but just wanted some opinions my thinking is if I don't like plati dip I can peel it off
LJ_Cool 05-22-2013 11:24 AM
Depends on how thick you plasti cote it, the rubber is great for sprayed on thin coats, but I think some other bed liner type product would be more durable, especially when put on over your attempt to "knock the rust out"
Bradleyselma 05-22-2013 11:26 AM
What would you guys recommend if i was to bed liner it?
roosr 05-22-2013 02:15 PM
Monstaliner - http://monstaliner.com/
Line-X - http://www.linex.com/
LizardSkin - http://www.lizardskin.com/
Herculiner - http://www.herculiner.com/
Just as starters. Might be much better, and definitly more durable than plastidip
ORfishinjeep 05-22-2013 02:44 PM
Al's Liner has a kit with spray gun for bed liner and they also have a material to spray over the top for noise and heat reduction.
http://www.alsliner.com/alsHNR
This is the direction I am leaning to do my inside tub.
Bradleyselma 05-22-2013 02:52 PM
Ok I'm not wanting to crack out too much cash
nmtj 05-22-2013 03:10 PM
Plasti dip will not last if anything comes into contact with it. Sprayed the backseat area and it started coming off in a few weeks
The time now is 06:54 PM.
