plans with dimensions for front bumper? - JeepForum.com
post #1 of 7 Old 09-13-2009, 05:54 AM Thread Starter
Atar
Hello,
Does anyone have plans with dimensions for front bumper like that HighRock 4X4 Front Bumper, or similar?
I tried to order from Quadratec, but the price and all delivery costs and charges up in Romania exceeds $ 1000.
I prefer to try to build one here if I get the plans and I will post here photos during fabrication.
Thank you
Atar is offline
post #2 of 7 Old 09-13-2009, 06:09 AM
little_Jeep
Post up a link to this High Rock 4x4........ add a photo of bumper you are talking about....
little_Jeep is offline
post #3 of 7 Old 09-13-2009, 09:14 AM Thread Starter
Atar
Since I have not 25 posts yet I could not attach pictures, but try it.
Or something as similar.
Atar is offline
post #4 of 7 Old 09-13-2009, 11:44 AM
BubbaGoose
BubbaGoose is offline
post #5 of 7 Old 09-13-2009, 12:04 PM Thread Starter
Atar
Yes. In the first 4 photos is Smittybilt XRC Front Bumper.
The following is the Bestop HighRock 4X4 Front Jeep Bumper.
Are similar in design, and one of the models I want to make it, depending on what plans found.
Atar is offline
post #6 of 7 Old 09-13-2009, 06:59 PM
little_Jeep
Personally, I don't think this bumper would be that hard to fab up. The main section appears to be 2" x 6" x 3/16" tube stock, cut long enough to cover the front of both frame rails, on top is piece of 3/16 flat stock that runs from 2x6 back towards grill. Bumper is bolted to frame rails thru this flat stock using factory bolt locations (but with grade 8 bolts). This flat stock is drilled for winch to bolt to it (use grade 8 bolts), then there is a the tabs for a roller flairhead to bolt to. Under the 2 x 6 stock will be two tabs made from 3/16 flat stock that will bolt to frame rails using factory bolt locations (bolts grade 8). The clevis tabs are run thru the 2x6 stock just inside the frame rails, and are welded front and rear... All welds are double sided welds including the top 3/16 flat stock that winch will be bolted to... The end caps and Chrome bar are for cosmetics. The end caps are nothing more than 3/16 flat steel. Remove your factory bumper and get a tape, I bet you can mock this sucker up in a few minutes.
I ignored the silly roller thing,...... you couldn't pay me enough to put this on my Jeep
post #7 of 7 Old 09-19-2009, 09:54 AM Thread Starter
Atar
If I can not have one this size, I will start next week to make a cardboard template.
Atar is offline
anyone have plans for a rear bumper jerseyrider1119 YJ Wrangler Technical Forum 3 11-03-2009 11:28 AM
Any Front Bumper Drawings Or Plans shockwavetj01 TJ Wrangler Technical Forum 2 09-26-2008 10:03 AM
Front/ Rear Bumper Dimensions GDTIME TJ Wrangler Technical Forum 2 07-01-2008 06:39 PM
TY vs YJ bumper bolt dimensions? Panteradon YJ Wrangler Technical Forum 0 07-26-2005 05:32 AM
where can I find plans for a cutom front bumper? AirforcebuddyTJ TJ Wrangler Technical Forum 5 04-26-2005 10:29 PM
