Pitman Arm Tie Rod - How to replacement - JeepForum.com
post #1 of 22 Old 05-26-2011, 07:40 AM Thread Starter
esad_b
So tonight (weather permitting) going to try and replace the tie rod that's connected to the pitman arm. It looks in horrific shape as you can see from the pics. The grease doesn't even stay in there.
Question is how does one remove this? First unscrew the tie rod end from drag link? Then use a puller to seperate the pitman arm and the tie rod end? Or vice versa? Because I don't think a puller will fit over on the top side of the pitman arm to separate the two?
esad_b is offline
post #2 of 22 Old 05-26-2011, 07:56 AM
samger2
It's a fairly easy process. Sometimes the ball joint can be a PIA to get out of the pitman arm. Are you replacing the entire drag link or just the ball joint on the end that goes into the pitman arm? If that's all you're replacing it should be really easy. Pull the cotter pin, remove the nut and then smack the drag link up near the pitman arm downward until the ball joint seperates from the pitman arm. Or if you have room smack the ball joint on top where it goes through the pitman arm until it falls out.
If you're replacing the entire drag link, there's just a few more bolts to remove, one from the steering stabilizer, one where it connects to the R/F knuckle and one where it connects to the track bar.
samger2 is offline
post #3 of 22 Old 05-26-2011, 08:10 AM Thread Starter
esad_b
Replacing the tie rod end itself. Not the entire drag link but just like the thing that screws into the drag link.
So smack it out from the pitman arm and then unscrew it from the drag link? I guess I was using the wrong terms and when I was saying tie rod in my previous post i meant drag link.
esad_b is offline
post #4 of 22 Old 05-26-2011, 08:20 AM
samger2
See this page for a good description of the parts and names.
http://www.quadratec.com/jeep_knowle...article-48.htm
But yeah, if all you're doing is that ball joint, it'll be easy. But the base of the bolt that goes up through the pitman arm is slightly tapered so it wedges in, so it can be difficult to get out...most likely won't just fall out when you take the nut off. As I said, you'll have to smack it, or the drag link itself for it to pop out.
samger2 is offline
post #5 of 22 Old 05-26-2011, 08:32 AM Thread Starter
esad_b
Yah I saw that picture before on 4x4xplor. I went to dig it up right before you posted that.
Thanks for the info, going to give it a shot tonight.
esad_b is offline
post #6 of 22 Old 05-26-2011, 08:34 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Use a PA puller.
TheBoogieman is offline
post #7 of 22 Old 05-26-2011, 08:35 AM
samger2
You may want to get an alignment afterward...but don't take that for Gospel...read the writeup on that 4x4xplor page on doing an alignment if you want to do it yourself.
samger2 is offline
post #8 of 22 Old 05-26-2011, 08:37 AM
samger2
Use a PA puller.
Yeah, a pitman arm puller on top of it will work well to push the ball joint out if you have one. I actually don't have one, so I used the hammer smack method
samger2 is offline
post #9 of 22 Old 05-26-2011, 08:40 AM Thread Starter
esad_b
Use a PA puller.
A puller will fit in there upside down? I didn't think there was enough room up in there to put one.
Do have one and I guess i'll give that a try also.
esad_b is offline
post #10 of 22 Old 05-26-2011, 08:43 AM
samger2
That was my concern too...I guess it's worth a try.
samger2 is offline
post #11 of 22 Old 05-26-2011, 08:49 AM
oscartj
My pitman arm puller was too big to get in and get a good hold. Just smack the side of the pitman arm where the tie rod end tapered shaft goes thru.
FYI: it's a tie rod end, not a ball joint.
oscartj is offline
post #12 of 22 Old 05-26-2011, 08:50 AM Thread Starter
esad_b
Tap the side of the pitman arm? Why are the other two saying to tap the ball joint thread at the top or the actual tie rod end?
esad_b is offline
post #13 of 22 Old 05-26-2011, 08:58 AM
oscartj
Try the other two ways, when that doesn't work, try what I said. It will fall right out.
oscartj is offline
post #14 of 22 Old 05-26-2011, 08:58 AM
samger2
It's a tie rod...you're correct. I tend to call it a ball joint because there's a ball joint in the end of it.
You can hit either spot. If you're disassembling your suspension and re-using it all then I wouldn't suggest smacking the top of the ball joint bolt/thread...but since you're replacing it, there's no concern of boogering up the threads. To me it seemed to help by getting downward force on the end of the tie rod/ball joint itself. But whatever works for you. Again, it doesn't matter if some damage ocurrs to the tie rod that's coming out since it's being replaced anyway.
samger2 is offline
post #15 of 22 Old 05-26-2011, 09:03 AM
oscartj
Please tell us where the drag link is connected to the track bar.
oscartj is offline
pitman drag link replacement 2001 quickslver TJ Wrangler Technical Forum 5 09-13-2010 08:28 PM
Looking for D30 axle seal replacement and Ball Joints Replacement Write Ups pfifer TJ Wrangler Technical Forum 1 04-14-2010 06:49 AM
Clock Spring - Pitman Arm Replacement imbezol TJ Wrangler Technical Forum 2 03-13-2008 08:47 PM
Pitman shaft seal replacement aussielaxr TJ Wrangler Technical Forum 1 03-12-2006 02:00 PM
drop pitman arm and pitman from XJ bighair YJ Wrangler Technical Forum 4 05-28-2002 01:10 PM
