PISSED! OEM Spare Tire Carrier Bolts Just Spinning, Can't Get Spare Off! IDEAS!?!
#1 | |
Well, I got a flat here in Chicago tonight. Windchill negative two and I just spent the last two hours on the side of Lakeshore Drive with traffic buzzing by trying to get two (of three) lugs off my spare but the bolts they were threaded on just kept spinning with the lug.
A fellow TJ stopped to give me a hand but neither of us could get it, even together. Tried prying / pinning the bolts, PB Blaster, the whole nine yards (this guy was a saint, spent 45 minutes with me on the side of the road). Thankfully, he had a portable compressor and I was able to get to a 24 hour shop. Mechanic's impact wrench couldn't even get it off. Bolts just spin. Patched and sent me on my way but I still need to get this f'in spare off? I'm literally about 8 hours away from taking a sawzall to the rim (they're echo's and I could use an excuse to get some cragers I've been eying). Any suggestions, insight? This happen to anyone else?
#3 | |
Yeah... not gonna work if hes still got the 3rd brake light mounted... deflate the tire to get access to the stud on the back, pair of vise grips to keep it from rotating and PB blaster it !! |
#4 |
This happened to me a few months ago....all you have to do it remove the rear breaklight,4 screws I believe, than you can get a welding rod in the carrier and tack weld it....5 minutes and you are set!!!!!
#5 | |
JEEP FREAK
![]() Why not?
98 TJ |
#6 | |
I rotate my tires every 5k my friend. Just had it done this summer! So this is a recent development. How is deflating the tire going to get me access to the stud? It's the rim that's in the way. |
#7 |
How do you get the brake light off with the rim and spare still on?
#8 |
#9 | |
JEEP FREAK
Can you break the stud by hammering on the lug nut, or does your Ecco style wheel have the lug nut recessed in a hole in the wheel?
98 TJ |
#10 |
Farm Wheeler
Drill progressively larger holes in the stud until you are able to bust the nut off. If the stud wants to turn with the drill, put a socket on the nut, hold the socket with a pair of vice grips, and run the drill through the drive hole of the socket.
Keep in mind that free advice can frequently be worth less than you pay for it. |
#11 |
Another reason why I run no tire carrier and keep my spare in the tub.
OP: You should be able to drill into the stud and use a socket to hold the nut and run the drill through the hole in the socket. edit: Just saw MDMs post. Wow, some people think alike eh? ![]()
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#12 |
Try a die grinder with a thin blade, cut the sides of the lug nut, then hammer and chisel the remaining piece of the nut off the stud. Good luck.
95 YJ 8" of lift 36" Iroks, & more mods than I can really afford. The General Lee....YEEEEHAAWWW http://s488.photobucket.com/albums/rr249/jerseyjeep2003/General%20Jeep/?action=view¤t=trailride7-6-08105.jpg |
#13 |
![]() ![]() Good luck |
#14 |
Pull on the wheel and use an impact wrench...
#15 |
good advice, thanks. I'll give it a try.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
