Pionion angle ? - JeepForum.com
post #1 of 2 Old 01-15-2010, 04:15 AM Thread Starter
outlawjosywales
Pionion angle ?
My rig needed new springs so I bought a set of 4.5" RE. They are a little taller than the 4" Terflex I have on now. They measure about 1/4" taller for the rear & 3/4" taller up front (from what my Tera's measured when I first got them). So I'm going to extend my lower control arms out about 1/2"-3/4" from where they are currently at to match RE fixed arm length for the 4.5" kit. My question is how much do you think this will affect my pinion angle? Noticeably to where I'll have to readjust it or will I be able to get away with not having to adjust the uppers? TY.
Go Anywhere.
outlawjosywales is offline
post #2 of 2 Old 01-15-2010, 05:33 AM
robncar
robncar's Avatar
The best way to tell is to measure with an angle finder. They're at Lowe's, Home Depot, Sear's, etc. for about $10.
Remember, lowers set wheelbase, uppers set pinion angle...
00939840000-1.jpe
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
Front pinion angle vs. driveline angle Jeepin' Rock Cl TJ Wrangler Technical Forum 19 11-01-2016 04:02 PM
CV drive shaft angle vs. pinion angle mdm TJ Wrangler Technical Forum 7 12-01-2009 05:36 AM
what's the stock angle on TJ engine and trans? centerline angle... thelazerviking TJ Wrangler Technical Forum 2 03-29-2007 08:20 PM
Tip Over @ What Angle? Jcpierc21 TJ Wrangler Technical Forum 19 02-07-2005 04:17 PM
Too much angle? TJSilverSport02 TJ Wrangler Technical Forum 4 06-15-2003 06:11 PM
