Pinion seal for u bolt yoke conversion - JeepForum.com
post #1 of 16 Old 06-27-2013, 06:36 AM Thread Starter
JoshuaZ
Does anybody know where I could source the pinion seal for a unbolt yoke conversion, the seal is different than the factory size and I would prefer not to spend $70 on a full kit just to get the seal. There was no numbers on the seal itself and when I called Quadratec they don't just sell the seal.
Thanks
JoshuaZ is offline
post #2 of 16 Old 06-27-2013, 08:17 AM
biffgnar
biffgnar's Avatar
Recently changed my HP30 pinion seal and I have u-bolt yoke and the pinion seal was the same. Not sure I understand why it would be different. The pinion and housing sizes which are what are being sealed don't change. It is just the yoke to driveshaft connection that is different.
Romney in 2020!
biffgnar is offline
post #3 of 16 Old 06-27-2013, 08:47 AM Thread Starter
JoshuaZ
The ubolt yoke has a smaller diameter than the stock yoke so the original seal won't work. That's why I can't find them anywhere.
JoshuaZ is offline
post #4 of 16 Old 06-27-2013, 08:48 AM Thread Starter
JoshuaZ
The outside diameter of the seal is stock size the inner rubber seal is the issue, it needs to be smaller.
JoshuaZ is offline
post #5 of 16 Old 06-27-2013, 09:22 AM
biffgnar
biffgnar's Avatar
I don't understand how the diameter of the yoke has anything to do with it. The seal fits between the housing and the pinion. The yoke just bolts to the pinion. Don't see how the pinion cares what kind of yoke is attached to it. Unless pinion is a different size (which would be odd) seems to me the seal is the same. I know it is on my HP30.
Romney in 2020!
biffgnar is offline
post #6 of 16 Old 06-27-2013, 09:26 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Having done one u-bolt style yoke conversion on my previous TJ, I won't bother doing another.
First, the straps of the OE yoke are more than strong enough... they just don't break. Besides, it's not the straps that provide the strength, it's the yoke itself the u-joint sits in The straps just hold the u-joint down into the yoke that is the strength behind the design. Not to mention it's way too easy to overtighten the u-bolts & damage the bearing caps & needle bearings inside. Personally, I'm sticking with strap yokes even with my 1330 and 1350 size u-joints.
Jerry Bransford is offline
post #7 of 16 Old 06-27-2013, 09:31 AM Thread Starter
JoshuaZ
The inner part of the seal sits on the back of the yoke not the pinion. Ill post pics later it will be easier to explain
JoshuaZ is offline
post #8 of 16 Old 06-27-2013, 11:28 AM
rchase559
Assuming we are talking about a D30, D35, or D44, the pinion seal is pressed into the housing (more of hammered in) and the rubber part rides on a machined surface on the yoke. It doesnt touch the pinion at all. This is why you will sometimes see a worn out yoke when replacing a pinion seal.
OP: I can't really give you any specific answers but knowing what axle are you dealing with may help others help you. Can you measure the OD of the yoke where the seal rides?
rchase559 is offline
post #9 of 16 Old 06-27-2013, 11:39 AM
Spyder05
what axle are we talking about first off??
I know on my d44 I can slip over the pinion a d35 yoke from a tj or yj...both are d35 but they are different. but not all of those yokes will seal with my pinion seal. try a slightly different application.
05 Tj d44's, 4.88's, ARB's, 37's and some bling
99 TJuggy tons, 40's
14 RAM 1500
07 SRT 8 grand
Spyder05 is offline
post #10 of 16 Old 06-27-2013, 11:47 AM
biffgnar
biffgnar's Avatar
OK, I get that now. Just looked at a spare D44 seal I had lying around (although I don't have a D44 axle anymore). The OD of the yoke though must be really small if he is saying its not going to seal.
Romney in 2020!
biffgnar is offline
post #11 of 16 Old 06-27-2013, 11:56 AM
jeepmutiny
1983 CJ7
Take it over to Motion Industries, not only can they match it up but they will have many options as far as material and design such as triple lip or ceramic slinger....Jon
jeepmutiny is offline
post #12 of 16 Old 06-27-2013, 12:00 PM
biffgnar
biffgnar's Avatar
Interesting possibility. I just measured the inner hole in a D44 seal at approx. 40mm and the OD of an HP30 ubolt yoke at approx. 55m. Still seems like a decent amount of overlap if things got mixed up, but maybe not. I would have expected that comparison to be biggest seal to smallest yoke, but perhaps other combos are different.
Romney in 2020!
biffgnar is offline
post #13 of 16 Old 06-27-2013, 12:22 PM
ftgiles
Dana 30s and Dana 44s use the same yokes and the same seals. Just ask for a seal for an early model Jeep before they used strap yokes. '74 CJ-5 for example. That's what I tell the parts guy when I want the seal for my u-bolt yokes.
ftgiles is offline
post #14 of 16 Old 06-27-2013, 01:02 PM Thread Starter
JoshuaZ
I just bought a new yoke kit, I don't have the time to look for the right seal. $80 is worth it to be able to drive the jeep while its nice out.
JoshuaZ is offline
post #15 of 16 Old 06-27-2013, 02:13 PM
Spyder05
80$ for a seal...damn kid
14 RAM 1500
07 SRT 8 grand
Spyder05 is offline
