Pinion Seal Replacement dana 30 - Page 2 - JeepForum.com
post #16 of 43 Old 05-18-2011, 04:15 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by RaggedOleMan View Post
1. The d35 has a crush sleeve, the d30 does not.
I'm also about to do my d35, the critical issue is the crush sleeve. By over tightening it, the crush sleeve will compress further, and change the relationship of the pinion gear to the ring gear.
The LPd30 has a crush sleeve, the HPd30 doesn't.
If you over tighten the pinion nut and have a crush sleeve, the pinion bearing tolerance changes and may fail...
Knuckelhead is offline
post #17 of 43 Old 05-18-2011, 06:27 AM
jbarrett
So I guess I should take it to a shop. Thanks guys.
jbarrett is offline
post #18 of 43 Old 05-18-2011, 07:17 AM
MO2500
While over tightening would crush the sleeve, it won't change the relationship of the pinion gear to the ring gear. The pinion is shimmed for pinion depth under the bearing or race. What crushing the sleeve will do is greatly increase you pinion bearing pre-load and lead to pinion bearing failure as Knuckelhead mentioned.
I'm not trying to make it sound less crucial because it is extremely important to maintain proper bearing pre-load. However, the crush sleeve is not used to set pinion depth and does not effect the gear setup.
Originally Posted by jbarrett View Post
Hey Guys - this is a good guide and I would like to try and follow it to replace my own pinion seal leak. I had a few questions.
1. This is for a Dana30 - I have a Dana35. I'm assuming it's the same.
2. How do you truly get the pinion nut back on? The service manual says before removing the nut, you need to measure the torque required to turn the yoke several times. Can you really (and accurately) mark the location of the nut prior to removal? What's the tolerance or room for error?
3. Does the new seal need to be "seated" with a special tool? I had heard that you need a "seal set" to correctly align the pinion seal because it needs to be perfectly centered.
Thanks!
1. Same procedure for the D35 as the low pinion D30 that comes stock in non-rubicon TJs and LJs. They both use crush sleeves so maintaining bearing pre-load is important.
2. the truly accurate way to do it would be to remove the carrier, measure pinion bearing preload using an inch pound torque wrench and take note. Then reassemble with a new crush sleeve and new pinion nut and gradually crush the sleeve until achieving the desired bearing pre-load.
This is not the only way to do it. As was done with this write-up, marking the pinion nut and pinion threads and then tightening back to that same mark or just a 1/16" past works fine. You MUST use red loctite on the old pinion nut though. They are considered a one time use nut so they will want to back off if re-used without loctite.
Another method is to tighten the pinion nut to somewhere between 165-180 ft-lbs using a new pinion nut. The idea here is that it maintains a tolerable bearing pre-load since it takes over 200 ft-lbs to crush the sleeve.
I have personally tried both of these methods, one when changing the seal on my D30 and the other when changing it on my D35. I have not had any problems since.
3. Carefully tap the seal in straight and evenly. do not try and seat one side first and then the other. I used a small hammer and gently tapped around the edge of the seal until it was fully seated.
If your have some mechanic skills you can preform this job. I think the biggest problem most will run into is removing the pinion nut which usually requires a very large breaker bar and a lot of grunting as someone else stands on the brakes to keep the jeep from moving. A strong impact gun can do the job as well. Since the pinion nuts are designed to lock on the threads they can be a PITA to remove.
Instagram: @omsmike
MO2500 is offline
post #19 of 43 Old 05-18-2011, 07:25 AM
freeskier93
Since it was asked, a race and seal driver set is the tool you would use to push in seals. But as others have said there are other ways. A set is like 40 bucks or so, it would only be worth it to buy a set if you set up gears and to to press in bearing races.
Of course you don't even need the kit for races, but if your doing gees you minus well sped the 40 bucks.
freeskier93 is offline
post #20 of 43 Old 10-07-2011, 10:20 AM
NAlbertaTJ
How about the seal replacement on the D44 in the rear?
NAlbertaTJ is offline
post #21 of 43 Old 10-07-2011, 08:32 PM
MO2500
Same procedure to replace the seal. However, the D44 is shimmed for correct pinion bearing pre-load so there is no crush sleeve. Just torque to spec with a new pinion nut.
Instagram: @omsmike
MO2500 is offline
post #22 of 43 Old 10-07-2011, 09:50 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Can you send me a link to one that has big holes in the seal pucks to clear the pinion?
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #23 of 43 Old 10-08-2011, 02:12 PM
NAlbertaTJ
Do you happened to know the torque spec for the pinion nut? Or should I just check with a torque wrench first before removing the old one.
post #24 of 43 Old 12-15-2011, 03:37 PM Thread Starter
RaggedOleMan
Update; For what it's worth, I recently swapped out my d35 pinion seal, too, using the same procedure. I did not, in either instance, swap out the pinion nut, I used locktite. That was a budget decision, nothing more. Then I drove it 800 miles back to the Seattle area towing a trailer without incident.
Thanks KnuckelHead & MO2500...
RaggedOleMan is offline
post #25 of 43 Old 02-22-2012, 12:10 PM
ariddhag
Napa seal
Was your Napa seal part number 15525 for the Hp30? I have a 97' TJ with (i think ) the original Lp 30? is it the same seal?
ariddhag is offline
post #26 of 43 Old 02-22-2012, 05:01 PM Thread Starter
RaggedOleMan
Yes...
post #27 of 43 Old 02-22-2012, 05:32 PM
TJRHD
Great write up man!
NOT A HATER
TJRHD is offline
post #28 of 43 Old 02-22-2012, 06:27 PM Thread Starter
RaggedOleMan
Originally Posted by TJRHD View Post
Great write up man!
Thank you...
post #29 of 43 Old 02-19-2013, 02:54 PM
Nasty25
I see this in my new future, great write up!
98 tj, 6 in lift, 35 bfg's, wheels, bumpers
Nasty25 is offline
post #30 of 43 Old 07-15-2013, 07:44 PM
Hosejockey61
A little thread revival for clarification of part numbers.
NAPA has the part number listed above for '02-'06 TJ's.
For '97-'01, they have part number 15791 which is a SKF Chicago Rawhide seal. The 02-06 price is $7 and the other is $43....go figure...
Hosejockey61 is offline
d30 , dana 30 , pinion , pinion seal
Dana 35 Pinion Seal replacement question 95wrangler4life YJ Wrangler Technical Forum 30 10-10-2012 02:21 PM
D30/D35 pinion seal replacement raskull TJ Wrangler Technical Forum 19 08-22-2008 09:57 AM
D30 pinion seal replacement jeep_chinto TJ Wrangler Technical Forum 9 03-13-2007 08:20 PM
Dana 44 Pinion Oil Seal Replacement??? pbungar TJ Wrangler Technical Forum 3 08-23-2005 09:27 AM
Pinion seal replacement Polaris TJ Wrangler Technical Forum 6 06-06-2003 12:05 AM
