Pinion seal replacement - JeepForum.com
post #1 of 7 Old 06-05-2003, 10:30 PM Thread Starter
Polaris
Polaris's Avatar
As time goes on, I get more and more fed up with my beloved TJ. The auto tranny has been rebuilt twice (under warranty, both times clutch packs and kickdown band, with the last being the torque converter as well.), a bad TPS, a camber alignment problem that never seemes to be remedied, and now, only after 46,000 miles the rear pinion seal is goin to poop. (sorry if this doesn't seem like much to gripe about, but I'm just blowin' off steam ) My question to you guys is if any of you all have had experience with changing this... this is an excerpt out of my Haynes manual:
11: Coat the threads of a new pinion shaft nut with multi-perpose grease and, using a holder to hold the flange, tighten the nut just enough to eliminate all end-play in the pinion shaft.
12: Turn pinion yoke to seat seal.
13: Using a torque wrench, see how much torque is required to turn the pinion shaft. The desired preload is the previously recorded value plus five in-lbs. If the preload is less than desired, retighten the nut in small increments until the desired preload is reached. If the maximum torque (plus five in-lbs reqiired to loosen the nut on disassembly) is reached before the preload figure is obtained, the bearing spacer must be replaced by a repair shop.
Note: do not back off the pinion nut to reduce the preload. Proceed to the next step after the preload is properly obtained.
I can understand everything up to this point (end-play, preload)... I am pretty good with tools and do all of the upkeep that my Jeep needs, but is this over most people's heads? I really want to save a few bones doing it myself rather than taking it somewhere. Any help would be appreciated!
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
Polaris is offline
post #2 of 7 Old 06-05-2003, 10:34 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It reads to me like you're talking about the procedure for setting the pre-load and crush sleeve inside the axle housing on the pinion shaft. If you're really just talking about the pinion seal itself, that just taps with a seal setting tool (or a smooth-faced hammer, carefully used) in until it's flush with the case.
Jerry Bransford is offline
post #3 of 7 Old 06-05-2003, 10:45 PM Thread Starter
Polaris
Polaris's Avatar
Exactly... if you overtighten the nut (preload?) you run the risk of crushing the collapsable spacer and/or bearings. If that happens it says to take it to a shop. What I want to know is that if it's an easy enough procedure to take the risk... again, I really don't want to take it in anywhere (i'm 19 and have a lack of $ )
P.S. Just wanted to say thanks Jerry for all the help you've given me throughout all these posts
Polaris is offline
post #4 of 7 Old 06-05-2003, 10:57 PM
Kodiak
Kodiak's Avatar
Just out of curiousity, what was your tranny doing (how was it acting) when you had to get it replaced?
Sorry, can't really help you with your pinion seal question. But, I may be able to email or fax to you the pages that describe the procedure in the FSM. PM me and I'll see what I can do.
Good luck.
Kodiak is offline
post #5 of 7 Old 06-05-2003, 11:02 PM Thread Starter
Polaris
Polaris's Avatar
It slipped upon acceleration pretty harshly and during kickdown acceleration while highway driving
Polaris is offline
post #6 of 7 Old 06-05-2003, 11:13 PM
Jerry Bransford
Administrator
Just tighten the pinion nut to 120 ft.lbs and you'll be fine. That's tight enough to hold it well but not so tight that it will hurt the crush sleeve. Try to use a new pinion nut though... pinion nuts aren't supposed to be reused.
post #7 of 7 Old 06-06-2003, 12:05 AM Thread Starter
Polaris
Polaris's Avatar
Well damn... that sounds easy! Thanks!
Polaris is offline
rear pinion seal replacement? 70ssclone TJ Wrangler Technical Forum 3 12-15-2008 08:23 AM
D30/D35 pinion seal replacement raskull TJ Wrangler Technical Forum 19 08-22-2008 09:57 AM
D30 pinion seal replacement jeep_chinto TJ Wrangler Technical Forum 9 03-13-2007 08:20 PM
pinion seal replacement Muddeprived TJ Wrangler Technical Forum 38 09-07-2005 04:56 PM
Pinion seal replacement boomhower YJ Wrangler Technical Forum 3 08-10-2005 08:37 AM
