pinion seal replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > pinion seal replacement
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 02-02-2005, 11:53 AM   #1
Muddeprived
I checked the faq's and did some searches but didn't find any write-ups on replacing the rear axle pinion seal. Mine started leaking due to the vibes from the sye and not adjusting the pinion angle (just ordered upper adjustables). I want to tackle this plm myself so can anyone point me to a good write up on this? I don't have a hayne's or chilton's manual.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Unread 02-02-2005, 11:58 AM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Getting it out without a pinion seal puller is just a matter of cutting (I usually just carefully cut it with a flat bladed screwdriver and hammer) it enough to be able to grab it with a set of visegrips and/or needle nose pliers and peeling it apart enough to get it out. It's basically removal by destruction. Be VERY careful not to nick or scratch the machined surface it must seat against though.
Use a Chicago Rawhide brand seal, since it is less prone to problems inserting it without damage, and then carefully tap it into place with a rubber mallet and/or a flat seal replacement tool. Try to avoid cocking it to one side, which is admittedly not easy to do, as you tap it into place.
I tackled my first one with about this same level of advice and got it done ok.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 02-02-2005, 12:17 PM   #3
Muddeprived
Thanks jerry. I did see some posts throughout the forums but some of them differed from the others and was a bit confusing on which to follow. I did replace the wheel bearings on the rear axle and had to remove that seal which is similar tot he pinion seal (looks-wise). Should be an easy fix.....
we need bulletproof seals that never leak......but that takes all the fun out of it
Custom snorkel
Detours/winch
Unread 02-02-2005, 12:31 PM   #4
pushead
I used a race kit to put mine on. I had rented it from auto zone to finish some work in my rear diffrential. The kit comes with multiple sized disc. One of them will be the same diamater as the outer rim on your seal. Line it up and smack it in. The race setters are made of aluminum too, so your seal wont take a beating.
Its not a jeep if it dont have 4wd.
pushead is offline   Reply With Quote
Unread 02-02-2005, 01:06 PM   #5
ColoradoSkier
Be sure you check the torque setting on the pinion nut before you take it off. Very easy to over-tighten when re-installing, and that causes bad things (yes, speaking from experience).
Chester Bullock, [EMAIL]chester@tenxible.com[/EMAIL]
98 TJ, [url=http://bullockfamily.com/photos/gallery.php3?catid=4]pics are online[/url]
1" ProComp springs, 31" BFG AT's, [url=http://www.atozfabrication.com/?source=chester]AtoZ Fab Rockers and bumpers[/url]
Tenxible Solutions
Website Hosting, Design and Marketing
[URL]http://www.tenxible.com[/URL]
ColoradoSkier is offline   Reply With Quote
Unread 02-02-2005, 03:05 PM   #6
gksspot
do a search, there is a jeep site called jeepinsingles or something like that and they have a decent writeup and pics
[SIZE=1][COLOR=blue]97 TJ Sport Patriot Blue
- 4" susp. lift, 1" BL, & 1" MML
- Dana 30/44 - 4.88s - 35 inch Xterrains
- Tuffy Stereo Center Console - LED Tailights
- Big Daddy Rock Rails - Durabak'd Tub Grey
[URL=http://www.cardomain.com/memberpage/445466]my site... [/URL]
BLUE JEEP CLUB MEMBER #63,112
TIRED OF BB THREADS IN TJ FORUM MEMBER #1[/COLOR][/SIZE]
gksspot is offline   Reply With Quote
Unread 02-02-2005, 06:24 PM   #7
deadman
Here's how i do Pinion seals at the GM dealer. Mark the pinion to yoke relationship. Count the number of exposed threads(write it somewhere). Un bolt the yoke and remove it. Remove the seal---a seal remover from Sears Hardware works well. Install the new seal and reinstall the yoke in the same relationship to the pinion. Tighten the nut slowly until the same number of exposed threads show.
deadman is offline   Reply With Quote
Unread 02-02-2005, 06:29 PM   #8
Keith_C
Why would that matter ?
Keith_C is offline   Reply With Quote
Unread 02-02-2005, 06:32 PM   #9
greenmachine99
So the drive shaft will bolt right back in place because nothing was moved.
greenmachine99 is offline   Reply With Quote
Unread 02-02-2005, 06:33 PM   #10
Spiderman
AFter seeing a mechanic replace my rear seal in less than 10 minutes, I'll leave it up to the pros. Especially when you can mess up the rear end when you tighten up the pinion nut.
[URL=http://tednugent.com][COLOR=Red]www.tednugent.com[/COLOR][/URL]
[SIZE=1]
[COLOR=navy]2001 Sport 4.0L, 5 Speed, Patriot Blue
33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels
4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML
Aussie D30 Locker, & other crap[/COLOR][/SIZE]
Spiderman is offline   Reply With Quote
Unread 02-02-2005, 06:47 PM   #11
JeepCrazyKid
not only the pinion to the yoke, but also matchmark the driveshaft to the pinion yoke. You want to put everything back together the way it was balanced.
JeepCrazyKid is offline   Reply With Quote
Unread 02-02-2005, 06:52 PM   #12
Keith_C
If the yoke was really balanced with the driveshaft, that'll be lost when replacing the driveshaft anyway.
Unread 02-02-2005, 07:24 PM   #13
greenmachine99
Its not balanced perfectly but a spline or 2 left or right will give you some vibes and you'll go through U joints.
Unread 02-02-2005, 07:25 PM   #14
JeepCrazyKid
who's replacing a driveshaft? he's doing a pinion seal.
Unread 02-02-2005, 08:09 PM   #15
greenmachine99
Yes, well you have to take off the driveshaft to get to the pinion nut.
