pinion seal ? - JeepForum.com
post #1 of 15 Old 11-24-2010, 09:07 PM Thread Starter
pile_alcalineNJ
pinion seal ?
so im about to get elbow deep in a pinion seal replacement this weekend, my major question is i hear the pinion nut needs to be replaced, any specific nut?
also anything i should watch out for while doin this?
Where did i put my doors?
pile_alcalineNJ is offline
post #2 of 15 Old 11-24-2010, 09:16 PM
TheStigX
Which axle?
It didn't seem that deep...
TheStigX is offline
post #3 of 15 Old 11-24-2010, 09:28 PM Thread Starter
pile_alcalineNJ
both
post #4 of 15 Old 11-24-2010, 09:49 PM
2003X
Ive done 2 pinion seals so far on my Dana 30 and I have re-used the nut both times with out issues. One thing I didn't have is a pinion seal puller. I got one from Auto Zone for $5. It made the 2nd time changing the seal a breeze. Please try to get it.
I would say if the nut is badly damaged replace it, but it shouldn't be.
There are several write ups, but I used this one.
JeepingSingles.net: Tech Section - Pinion Seal Replacement - TJ/YJ
My Build
2003X is offline
post #5 of 15 Old 11-24-2010, 09:57 PM
incredibull
Replaced D35 pinion seal two years ago, did not replace the nut. Replaced the nut while rotating pinion by hand to make sure bearings were properly seated (wheels off the ground). E-brake was enough to hold the axle in place for final torque of the nut to 150 ft-lbs. 30,000 miles later, no problems.
I don't have a pinion seal puller either, I just carefully pried the seal out with a very thin screwdriver, first knocking the seal rim out with a flat punch. Just be careful not to score the pinion housing lip.
When installing the seal, I also put a small bead of RTV along the rim of the seal where it meets the lip of the pinion housing.
incredibull is offline
post #6 of 15 Old 11-25-2010, 06:30 AM
hdsport
2008 WK
Replaced my rear pinion seal and used an air gun to torque the nut to ~120 lbs. My jeep mechanic was checking for a vibration and removed the rear driveshaft and then tried to turn the rear yolk by hand. It was very tight and you could feel a pressure "grinding" in the rear. You should be able to EASILY turn the yolk/rear gears by hand.....~7ft-lbs. A little more with the tires on. He backed off the nut to relieve the pressure and still have NO play in the rear bearings. Now rotated EASILY and NO grinding....smooth turning. I WAS VERY BLESSED that I didn't blow the rear!!!!!!!
Proper way to do this:
Count the # of threads you can see BEFORE removing the nut. Using a paint pencil, mark the nut and thread, so you can return the nut to the same EXACT position.Remove nut, replace seal, install nut and tighten to the SAME position is was before removal.
Rear should turn easily by hand with no binding or grinding.
Let us know how you make out.
hdsport is offline
post #7 of 15 Old 11-25-2010, 08:17 PM
deadowl87
I just did this on the front of mine, I counted threads, but the PB blaster made the white out marking I made on the bolt and nut way to runny, but it seems fine to me. I reused the bolt, the only advice I have for you is if you can't get your hands on a proper pinion seal puller, remember, the reason the seal itself is so hard to get off, is because it's been pneumatically pressed into place, plus the little rubber ring has melted the seal to the hole. attack the seal by trying to break the little rubber ring from the outer edge.
deadowl87 is offline
post #8 of 15 Old 11-25-2010, 08:47 PM Thread Starter
pile_alcalineNJ
word yeah, well i have a bunch of seals on their way to my house, ill deffinitly pick up a puller when i go get the fluid for it to. ill let you know how it all goes once im done
post #9 of 15 Old 11-25-2010, 08:59 PM
TheFog
Don't understand the issue with counting threads and putting back in the same position were taken off. When you torque the pinion nut back down the Ft-Lbs is what dictates how far/deep it will thread back on.
I changed the pinion seal on my D30 about 1K miles ago and just replaced the pinion nut with a new one and torqued it down to 150lb. When I installed my Aussie locker the other day I checked the pattern with some gear paint and it was still good.
FOG
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
post #10 of 15 Old 11-25-2010, 09:31 PM
TheStigX
FOG
My guess is that if you don't have a torque wrench, you can torque it back properly without guessing how much you actually torqued it.
TheStigX is offline
post #11 of 15 Old 11-25-2010, 10:47 PM
RaggedOleMan
Did my d30 pinion seal a few months back. Here's my write-up; http://www.jeepforum.com/forum/f9/pi...-30-a-1031177/
RaggedOleMan is offline
post #12 of 15 Old 11-25-2010, 10:47 PM
RaggedOleMan
post #13 of 15 Old 11-26-2010, 05:53 AM
blubaru2002
I replaced my dana35's pinion seal myself. It is a very straight forward process.
Later on down the road, my dana30's pinion seal started leaking. For some reason I was unable to get the pinion nut off of my dana30, so I had to pay a mechanic to do the work.
Guess which one is leaking now... ARRRGGHHH... I hate paying someone else to do the work.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #14 of 15 Old 11-26-2010, 06:13 AM
spitfiremkii
You should actually obtain an inch pound torque wrench, it has to be the cheapy beam style NOT the click type. Before you remove the pinion flange nut use the torque wrench on the nut to spin the pinion/axle assy. and record the torque reading. Do this three times to get an average reading of torque required to rotate it. Then when you re assemble after seal replacement SlOWLY tighten the pinion nut in small incriments, frequently rechecking with the inch pound torque wrench until you obtain the recorded rotating torque value, then add an additional 5 INCH POUNDS. There is a "crush sleeve" between the two pinion bearings that maintains preload on the bearing (a slight amount) and if you put the nut back to where it was when you took it off, the proper amount of preload will NOT be obtained, hence the additional 5 INCH POUNDS.
Hope this isnt too confusing...?
spitfiremkii is offline
post #15 of 15 Old 11-26-2010, 07:07 AM
erickpl
erickpl's Avatar
Is there a writeup for the D35 pinion seal writeup? I'm noticing a leak in mine too... Or is it similar enough to the D30 that I should follow that?
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
D44 Pinion Seal ajf1994 TJ Wrangler Technical Forum 10 10-28-2010 06:47 PM
D44 rear pinion seal vs. NP231 transfer case seal thejafe TJ Wrangler Technical Forum 14 06-14-2009 01:24 PM
Where to get rear D44 pinion pinion seal? Lud04X TJ Wrangler Technical Forum 2 02-22-2007 10:36 AM
Pinion Seal bonehead99 YJ Wrangler Technical Forum 3 09-02-2004 04:08 PM
