Pinion leak all of a sudden - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Pinion leak all of a sudden
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 01-24-2015, 10:31 PM   #1
DieselDog1
So both my front and rear pinion seals started leaking within a day of each other. They have both been bone dry for as long as I have owned it and now all of a sudden they are both leaking. The weather has been fluctuating like crazy, it has gotten below freezing but today was 50 degrees. Could the change in weather be wreaking havoc on the seals? It's just odd that they both just started leaking. I guess I'll take it in to get them replaced but was hoping to get some insight into why they started so quickly.
DieselDog1 is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 10:40 PM   #2
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Do you play in mud or water? If so you may have gotten water in the diff and then if you didn't change it, it froze and caused problems.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 01-24-2015, 11:34 PM   #3
DieselDog1
No mud or water, I learned my lesson with my last TJ that mud is only fun till you have to clean it off. I haven't been snow wheeling either so there shouldn't have been any way for water to get into the diffs. I checked my vent tubes as well and they both seem to be clean and working properly. I guess they could have both gone bad at the same time but it seems like an odd coincidence.
Unread 01-28-2015, 04:04 PM   #4
DieselDog1
Holy crap I got a quote to get them replaced and they want $440 to do both front and rear seals and change the fluid. Maybe I'm just a cheap skate but that's sounds a bit high.
Unread 01-28-2015, 04:19 PM   #5
blubaru2002
Haha. That is insane to pay that much money for such an easy job.
Do it yourself.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is online now   Reply With Quote Quick reply to this message
Unread 01-28-2015, 05:57 PM   #6
DieselDog1
It's 25-30 degrees outside right now and I hate the cold otherwise I would do it myself. I am going to call around and see what the average cost around here is for that job. It seemed a bit rediculous.
Unread 01-28-2015, 06:59 PM   #7
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
If you're talking about having them replace all of the seals in both front and rear axles, that's not that far out of the normal cost. If you're just asking about the front and rear pinion seal, yes that is a high price...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 01-28-2015, 08:46 PM   #8
rchase559
If they are doing it by the book, the price seems more reasonable. Since the rear axle is a D44 and doesn't use a crush sleeve, there is no worry of setting pinion bearing preload incorrectly. The front D30 however is a different story. If doing it the "right" way, the crush sleeve would need to be replaced which involves extensive disassembly of the front axle.
With that said, many (including myself) have replaced D30 pinion seals in the past without replacing the crush sleeve and haven't had issues.
I would ask how they plan on replacing the front pinion seal before I wrote off the shop entirely.
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2015, 09:13 PM   #9
DieselDog1
Just the pinion seals, they are going to index the pinion nut (is what he said) and not replace the crush sleeve or anything inside the diff. It sounds like that is way high for what it is. I am gonna call around and see if I can get a more reasonably priced quote. I hate not having heat in the garage when I need it because this would be getting fixed Saturday instead of chasing down quotes. Thanks everybody
Unread 01-30-2015, 02:22 PM   #10
DieselDog1
Called the local jeep dealership that I use for misc. parts to see what they would charge. $75 in labor for each pinion seal and another $75-100 for parts. So say $250 out the door in worst case I think that is worth me not having to turn a wrench in below freezing temps. I don't ever use a dealership for maintenance but they are going to get my business this weekend. I am going to call the other shop and see if the "mis-quoted"
Unread 01-30-2015, 02:43 PM   #11
ravenworks
ravenworks's Avatar
That's a fair price.
Why not just run it until spring?
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 10:21 PM   #12
DieselDog1
I drive the jeep every day on the interstate 60 miles round trip and I don't want the leak to get worse or fail and be stuck somewhere. I figured I do enough wrenching on this thing in decent weather I'll let somebody else do it when it's cold.
Unread 01-30-2015, 10:25 PM   #13
biffgnar
biffgnar's Avatar
Depends how bad the leak is. If really dripping then pay to have done now. If housing just wet drive as long as you need to, checking fluid level if too much time goes by.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-31-2015, 02:01 PM   #14
DieselDog1
Well it's enough to run down the diff housing and drip about a dime size puddle from the front diff. The rear is just wet on the bottom of the housing, I haven't seen anything on the ground from the rear diff.
