Pinion Angle after lift - JeepForum.com
post #1 of 5 Old 06-11-2012, 09:29 AM Thread Starter
01TJ-Bob
First off I know this subject has been covered many times but as yet I ahven't got a strait answer so here goes. I have a 2001 tj 4.0 5 speed and just installed a 3.5" Rancho short arm lift with 33" tires. Instead of drilling out the front track bar bracket I bought a RE adjustable arm. I did use the spacers for the transfer case drop and bought rear adjustable CA's. I'm getting a vibe in 2nd and 3rd gear at around 3-5k rpms. I DO PLAN ON THE SYE BUT CAN"T RIGHT AWAY. My transfer case angle is 8 degress my DS is 15 degrees and rear pinion is at 14 right now. What would the best angles be for the mean time until I get the SYE. My vibes are with Accel so I was thinking of dropping the pinion another degree if I go any lower the DS angle gets worse. Any suggestions please.
01TJ-Bob is offline
post #2 of 5 Old 06-11-2012, 10:29 AM
VT_Rubi
Do you have a CV driveshaft? If no CV driveshaft, and no SYE, you need to make your pinion angle parallel to the Transfer case output (the slip yoke). Make sure your differential u-joint doesn't bind. If it does, you need an SYE and CV driveshaft.
Once you get the CV driveshaft and SYE, adjust your pinion angle to match (or be ~1 degree less than) your driveshaft angle.
VT_Rubi is offline
post #3 of 5 Old 06-11-2012, 11:55 AM Thread Starter
01TJ-Bob
I adjusted my pinion the same as my transfer case at 8 degrees which made my DS angle at almost 20 degrees and the vibes increased big time so that's no good. As far as the CV shaft as I said it will have to wait until funds are available, I'm just trying to get vibes down to minimal for now.
01TJ-Bob is offline
post #4 of 5 Old 06-11-2012, 12:09 PM
99_TJ_Wyoming
With my 3.25" lift I didnt use the trans drop and I never changed pinion angle, I did use a 1.25" BL and a 1" MML, I never had any driveline vibes though
99_TJ_Wyoming is offline
post #5 of 5 Old 06-11-2012, 12:18 PM
Cuder
Drop the skid some more with washers and longer bolts or get a mild motor lift. The angles between the transfer case and pinion to the driveshaft needs to be 3 deg or less.
My Build Thread:
Cuder is offline
lift and pinion angle Apesteguy TJ Wrangler Technical Forum 1 02-22-2011 07:28 PM
pinion angle, 8.8 with 3.5 lift. lckdrgn YJ Wrangler Technical Forum 2 12-04-2010 09:47 AM
Front pinion angle with 4 in lift Rayne TJ Wrangler Technical Forum 1 06-22-2010 05:48 PM
Help with pinion angle after lift WhiteOut TJ Wrangler Technical Forum 6 05-07-2009 11:05 AM
4" lift & Pinion angle 4point TJ Wrangler Technical Forum 10 11-26-2006 06:47 PM
