Pinion angle - JeepForum.com
post #1 of 9 Old 12-28-2010, 08:41 PM Thread Starter
nthn1800
Pinion angle
I have 3" AEV coil springs on the way along with adj currie control arms. I have been doing a lot of reading to make sure I get a good idea of what all I need to do when I install the lift.
One question I have:
I know how to adjust the pinion angle, but how do I know when it is adjusted to where it should be?
Thanks!
nthn1800 is offline
post #2 of 9 Old 12-28-2010, 08:53 PM
wushaw
Rockin jeep
wushaw's Avatar
Do you have a SYE on your transfer case?
wushaw is offline
post #3 of 9 Old 12-28-2010, 09:10 PM
Benderff
Benderff's Avatar
http://www.stu-offroad.com/axle/pinion/pinion-1.htm
Benderff is offline
post #4 of 9 Old 12-28-2010, 09:16 PM Thread Starter
nthn1800
No, I don't. But that is something I am planning on doing in the future when I have the funds.
nthn1800 is offline
post #5 of 9 Old 12-28-2010, 09:22 PM Thread Starter
nthn1800
Originally Posted by Benderff View Post
thanks for the link. Does this only apply if you have a CV though?
nthn1800 is offline
post #6 of 9 Old 12-28-2010, 09:34 PM
Benderff
Benderff's Avatar
Did you read through it, and do you mean Slip yoke? You need a CV shaft, and a SYE before you adjust the pinion angle. Without the two you would need a transfer case drop, and/or a MML.
Benderff is offline
post #7 of 9 Old 12-29-2010, 04:57 PM Thread Starter
nthn1800
I am getting a MML and possibly a t case drop.
nthn1800 is offline
post #8 of 9 Old 12-29-2010, 05:06 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
click this: http://www.jeepforum.com/forum/f9/wh...ml#post8636577
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 9 Old 12-29-2010, 05:31 PM Thread Starter
nthn1800
Thanks, that helps!
nthn1800 is offline
control arm , lift , pinion , suspension
Front pinion angle vs. driveline angle Jeepin' Rock Cl TJ Wrangler Technical Forum 19 11-01-2016 04:02 PM
CV drive shaft angle vs. pinion angle mdm TJ Wrangler Technical Forum 7 12-01-2009 05:36 AM
pinion angle on 8.8 brooksjeep TJ Wrangler Technical Forum 1 04-07-2009 09:29 PM
8.8 pinion angle motorhead0320 YJ Wrangler Technical Forum 4 11-12-2007 07:29 AM
Pinion Angle Help? Wishin TJ Wrangler Technical Forum 2 02-28-2006 10:37 AM
