Pics from underneath- how's this look? -inspection - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Pics from underneath- how's this look? -inspection
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 06-02-2013, 08:17 AM   #1
citRon
Here's a visual test for all the mechanically inclined TJ'ers that work on their own Jeep (hopefully most here) and know what they're looking at-
a 2006 LJ with 100,000 miles on it. I'm looking at buying this Jeep and here are some pics of the undercarriage I requested. The pics are before any cleanup of the Jeep has been done, which is good.
The Jeep is in New England, so I was prepared for a lot of rust underneath but I was actually pleasantly surprised.
I see the seeping from the rear diff cover, the oil pan drain plug, and a couple possible axle seals. The rear axle pinion seal was replaced recently...
Anybody see anything I'm missing?
1996 Cherokee Country 4x4
citRon is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 08:20 AM   #2
citRon
Unread 06-02-2013, 08:20 AM   #3
TheBoogieman
Congrats DENVER BRONCOS!
TheBoogieman's Avatar
Looks really good for a northern Jeep.
If you don't like the opinions expressed here,then you really don't want to hear the ones I keep to myself.
TheBoogieman is online now   Reply With Quote Quick reply to this message
Unread 06-02-2013, 08:24 AM   #4
citRon
As soon as I get it I'll be under there with a wire brush, WD40 and Rustoleum. Normal maintenance stuff- o2 sensors, plugs/wires, fluids, track bar/sway bar bushings probably...it's not lifted and hasn't been off-roaded.
It's a one owner Jeep that has a list of service records form the dealership.
Unread 06-02-2013, 08:27 AM   #5
rchase559
What wires?
Just a heads up. It's likely not the oil drain plug that's seeping fluid but rather the rear main seal.
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 08:35 AM   #6
citRon
Originally Posted by rchase559 View Post
What wires?
plug wires- Ha! just remembered that it's an '06...I thought it may be the rear main too, and most likely is. Oh well- I've done it before; it's a suck job, but I can do it.
Unread 06-02-2013, 10:42 AM   #7
BYuen
I'd be most concerned with any rust, and looks like there's not much! The oil on the pain is probably from the rear main seal or the valve cover. Most of the TJs you find out there with the 4.0 will have developed a rear main leak by now.
BYuen is offline   Reply With Quote Quick reply to this message
