Pics of custom rear storage set ups. - JeepForum.com
post #1 of 14 Old 12-27-2004, 08:21 PM Thread Starter
Soon2AdjustYou
Soon2AdjustYou's Avatar
Hey all I did a search for this but only came up with a amo can idea. I like it, but I was looking for something similar to Stu's set up.
Anyone else have some ideas and pics
Former TJ owner...present YJ owner
Soon2AdjustYou is offline
post #2 of 14 Old 12-27-2004, 08:29 PM
cwlongshot
cwlongshot's Avatar
I want to do something above the tub. ALA trail rack made from tubing, w/sides.
I have seen some that mount to the roll cage just above the body/(tub) in the rear cargo area.
(I removed my rear seat, belts and bracketry long ago.)
I prefer to build it myself as oposed to just purchasing it.
Dont mean to hijack, just adding and I'll watch this!
CW
'99 TJ 4.0 5 spd D30 W/AUSSIE & 8.8 W/ECTED 4:10's
'89 MJ 4.0 AW4 Hi-Pinion D30 with SPARTAN D44 W/DETROIT LOCKER 4:56's
cwlongshot is offline
post #3 of 14 Old 12-27-2004, 08:35 PM Thread Starter
Soon2AdjustYou
I totally agree.......I'm plannin on building one myself
heres a thread at JU I dug up.....there are some awesome storage ideas in there!!
Storage compartment ideas
post #4 of 14 Old 12-27-2004, 08:42 PM
igofshn
Locked @ both ends
igofshn's Avatar
Here is what I have done. The rack is hinged so I can lift it up and down.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #5 of 14 Old 12-27-2004, 08:43 PM
DesertX04
I used tweba99's as model. I used mdf (seemed as cheap as anything) then cut out the middle portion for a hatch. It just rests on the top of the wheel wells, the front is supported by a sub box and I have to 2x4's supporting the rear (need to change that to make it look nicer). I also carpeted it w/some indoor/outdoor carpet. When I get around to it, I'll actually bolt it to the wheel wells and possibly fill in the front, but you can't see that part unless the seats are folded forward. I just finished it last week and am pretty happy w/how it turned out, considering this is my first attempt at woodworking. Plus, I wanted to spend my money on other projects.
http://www.jeepforum.com/forum/showt...hlight=storage
Alan
2004 X, 35's, Locked, Superwench, other stuff
DesertX04 is offline
post #6 of 14 Old 12-27-2004, 09:15 PM
cwlongshot
cwlongshot's Avatar
I like the look of Igofshn's model but I would move it up above the sides of the tub.
I also like rioshilo, from the link but I would need to add sides to both for when I am out wo/ the top in the summer.
Great pics guys!!!
CW
post #7 of 14 Old 12-27-2004, 09:52 PM
knight
knight's Avatar
i built 2 trunks now and i'm still changing designs.trunk
97 Jeep TJ 4 Banger
Poison spyder flatfenders,banks exhaust system,flex-a-lite fan,AR23 rims with bfg's and lots more to come in the future
knight is offline
post #8 of 14 Old 12-29-2004, 08:57 AM Thread Starter
Soon2AdjustYou
ok I think I have settled on a design
I'm going to make an X out of tubing
it will be welded or bolted to the four vertical roll bars in back
it will be just high enough where I can fit a duster on the rear cargo area. This will allow me to run my Bikini/windjammer/duster combo still
kinda like this but with the tire up top
yeah I know.......COG.........but I cant have a tire on the rear.......not with the stuff I drop off of.
what do you guys think?
post #9 of 14 Old 12-29-2004, 09:30 AM
RockRunner85
I like the above metals ones, however I can't weld so I built mine out of wood. I was on a tight budget so I went with some cheap wood. However if I was doing it again I would've spent the extra 20 bucks or so to get some nice particle board. The total cost came to approx 60 bucks.
I used 2x3s to build the frame. They slide-outs you can get at home depot or lowes in the hardware section. Their the 24" heavy duty ones. The box is approx 30 width x 24 long. I'm planning on placing 2 10" subs in the space in front of the box. You could make the box longer but I couldn't find any slide-out things long enough.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #10 of 14 Old 12-29-2004, 09:45 AM
igofshn
Locked @ both ends
igofshn's Avatar
Great pics guys!!!
CW
Mine was done that way to hold the spare down. It is perfect height for a 35x12.50 spare. The spare fits perfectly in the bed.
igofshn is offline
post #11 of 14 Old 01-07-2005, 11:19 AM
Jeepin_Jeffster
Jeepin_Jeffster's Avatar
Here's my homemade rack. I took some pics today for someone else & thought I'd post here as well...
'01 TJ with mods... :)
White Jeep Club Member #22
Jeepin_Jeffster is offline
post #12 of 14 Old 01-07-2005, 11:26 AM Thread Starter
Soon2AdjustYou
that looks sweet!
how is it mounted?
post #13 of 14 Old 01-07-2005, 01:04 PM
97TJGUZZY
97TJGUZZY's Avatar
has a slide out rack similar to rock runners, The top is just flush. Speakers mounted in the front in separate sealed boxes.
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
post #14 of 14 Old 01-07-2005, 02:12 PM
Jeepin_Jeffster
Originally Posted by Soon2AdjustYou
that looks sweet!
how is it mounted?
It's mounted to bolt's that already exist on the stock cage.
Custom Storage box done! ScottHarr_TJ TJ Wrangler Technical Forum 21 03-04-2009 12:33 PM
My custom rear bumper (pics) Baotchi TJ Wrangler Technical Forum 17 09-26-2007 10:11 AM
Rear storage box/rack with soft door storage DaveFL TJ Wrangler Technical Forum 17 04-20-2007 07:19 AM
My custom rear storage box setup and fold down tail gate CLynn85 TJ Wrangler Technical Forum 37 08-23-2006 06:50 PM
Custom Rear Storage sevise TJ Wrangler Technical Forum 3 03-31-2004 08:40 AM
