Quantcast Pics/advice for LED tails - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Pics/advice for LED tails
Old 04-14-2008, 02:44 PM   #1
Brew461
I am about the make the jump to LEDs. Any of you guys have a good source for LEDs with the reverse and side marker built in? How was the install? Got any pics? How are they holding up? Thanks in advance.
Mine: 03 TJ
Hers: 01 XJ
Brew461 is offline   Reply With Quote
Old 04-14-2008, 02:57 PM   #2
uscgjp
Depends on the look you're going for. If you want flush mount, QT/4WD both have some options. If you want to maintain something more along the lines of the stock lights, same sources have good options. I personally installed the Crystal Eyes LED Tail lamps - incredibly easy install: Mounted to the stock holes, wiring matched stock and didn't require the dreaded flasher fix. Loved them, until half the bulbs of one lamp went out and I'd have to spend another $200 for a new set... Seems like most jeep marketed lights have that whole cost issue.
My advice would be to convert to flush mount round LEDs - it's a bit of modification and body work on the jeep, but there is no shortage of great writeups and if blubs start burning out you can get replacements for $15 from a truck supply store. stu-offroad.com has a great install write up, or just run a search for it- Just a thought.
uscgjp is offline   Reply With Quote
Old 04-14-2008, 09:31 PM   #3
canjeeps
TJ Wrangler
yeah flush mounts are pretty cheap price wise but for most you have to do a little bit of cutting and stuff to make them fit. Personally i have oro litdots and love them. They look real nice and were easy to install. They arent cheap though.
White Sahara
canjeeps is offline   Reply With Quote
Old 04-14-2008, 09:47 PM   #4
Luke4554
Doing mine right now .. installs not bad if you buy the right sized hole saw.. i bought one about a quarter of an inch too small so ive been reaming the holes out with a dremel.
Get your lights from a trucking company, theyre usually better quality and you can get them for way cheap from their parts department.
My .02
Luke
[SIZE="1"][B]2000 TJ Sport[/B]
4.0L | 5spd | 4" SkyJacker | Soft 8's | 33" TRXUS | 30/35 | AA SYE/CV DS | SuperWinch | 4 KC's | Pure Bred Tube Fenders | EMPI Buckets | Novak Linkage| Pure Bred Bumpers | Bestop Tinted Soft Top & Bikini | HiLift | Yellow Top | Herculiner | JKS Discos | Skid Row Steering Skid
[b]Owner of [U]WWAutosports[/U] & [U]Pure Bred Fabrications[/U] Dayton, Oh[/b][/SIZE]
Luke4554 is offline   Reply With Quote
Old 04-14-2008, 10:16 PM   #5
Stu Olson
Stu Olson's Avatar
There is no such thing, anymore, as the "dreaded flasher" fix. You can purchase one of two available LED flashers (depending on the year of your vehicle) and plug it in without having to mod the flasher.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 04-14-2008, 10:28 PM   #6
deltabravo
hmmm.... I'm a vendor for all things LED.
LiteDOTs:
http://www.4x4led.com/stt/litedots.htm
Flasher:
http://www.4x4led.com/tips-flashers.htm
4": round, and many more: The 4" lights I sell are some of the better quality ones (and a name brand) not the generic no name brands that some other online stores sell
Note: when doing a flush (recessed) mounted 4" on 02 and newer TJs, some mods are required to the evap canister mounting location.
http://www.stu-offroad.com/engine/evapcan/evapcan-1.htm
Doug
www.4x4LED.com - LED lights for Jeeps, cars, trucks, trailers, etc.!!
Tiedowns for your Jeep trailering needs!
Envy4x4.com Suspension parts/kits, CBs and accessories and other Jeep doo-dads, MOLLE bags and packs too!
deltabravo is offline   Reply With Quote
Old 04-14-2008, 10:49 PM   #7
02tjsport
The evap thing is on 03 and up
www.vehiclelight.com
a few options on there. I have their 44 LED stop/turn/tail.
If you go with flush mounts or flange mount you will have to get some kind of back up light.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 04-15-2008, 12:12 AM   #8
Brew461
Thanks for the replies. Deltabravo: PM sent on the lite dots.
Mine: 03 TJ
Hers: 01 XJ
Old 04-15-2008, 05:36 AM   #9
singleshot
I'd stick with the recessed truck lights; cheap, easy to replace if needed and a snap to install. The best part about going with the truck lights is there are literally thousands of trucks on the road running them, so you can get an idea of brightness and desired look (rubber gromet or trim ring mount/ # of LED's and layout of LED's inside lights).
I stared at every truck I passed looking at the lights until I found the one I wanted. Then I just simply stopped by two different truck stops looking for the lights (ended up getting mine at a Pilot gas station). I think the total price for light/gromet/pig-tail was like just shy of $40.00 bucks. Pretty cheap considering the hole saw was $42.00 bucks . But hey, now I've got a 4.5 hole saw if I ever need it.
As far as the LED relay... Two different options are available; the EP-26 (4-pin) and the 5-pin LED flasher (I've totally forgotten the shop I got it from, but it was from a gentleman the posts here.. good guy and great shipping.. little plug for him).
I have never seen a recessed truck light with back-ups built in. I know there are probably some out there, just saying that I have never seen them. I went with the truck foglights as backup lights. When doing the wiring, it's pretty simply to drop the hot and ground down for the lights. Finding a suitable mounting location is dicy if you don't have a bumper built for foglights. What's nice about the truck foglight is it's a rubber housing and a complete sealed beam light snapped into it. So if something did happen to that light all it would take is for me to stop by the truck stop and spend 8.00 bucks on a new sealed beam and I'd be back in business. Regular foglights come in sets, so if you shattered one, you'd be buying a new set just to preplace that one.
If it has fasteners, I can take it apart.... Putting it back together is the real question.......
singleshot is offline   Reply With Quote
Old 04-15-2008, 09:55 AM   #10
Brew461
Thanks single shot
Mine: 03 TJ
Hers: 01 XJ
Old 04-15-2008, 10:01 AM   #11
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off)
TrailWorthyFab is offline   Reply With Quote
Old 04-15-2008, 10:44 AM   #12
kizer
http://www.links4jeeps.com/writeups/ledtaillights/
Im running ******* Tail lights myself. The brand up above mentioned by deltabravo should work just fine.
Just make sure you cut your hole smaller and work it larger. Nothing is worse than seeing an LED loose in the hole.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
kizer is offline   Reply With Quote
Old 04-17-2008, 05:09 PM   #13
Brew461
Allright, parts on order. I will let you guys know how it goes. I am going very simillar to what Kizer has going on.
Thanks for the advice Kizer. If you guys haven't checked out www.links4jeeps.com you should. Lots of great info over there.
Mine: 03 TJ
Hers: 01 XJ
Old 04-19-2008, 11:06 PM   #14
UTIJeeper
Let me know if you guys can answer me this. I put the gen-right leds on the front of my rig and did the flasher fix (97) and everything worked fine, now i just added 4" recessed leds in the rear and now my flashers still work fine with engine running lights off but when i turn my head lights on my turn signals don't work, but then if i put a load somewhere....like turn on the blower on full or turn on my off road lights they will flash once or twice. Its really wierd....i have tried a couple resistors on the ground side of my tail light circuit and that didn't help either...let me know if you guys know anything
Wheelin'
UTIJeeper is offline   Reply With Quote
Old 04-19-2008, 11:10 PM   #15
2005X
[QUOTE=kizer;5090128 Im running ******* Tail lights myself. The brand up above mentioned by deltabravo should work just fine.
[/QUOTE]
mesa 4x4 here too
at night you will be able to light up the car behind you
www.youtube.com/kgries
http://photobucket.com/kgries
in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash..
2005X is offline   Reply With Quote
Glock Forum
