Performance Speed mods?? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Performance Speed mods??
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 02-16-2010, 09:30 PM   #46
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
I wish I knew where to find extra power without spending a fortune! LMFAO
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline   Reply With Quote Quick reply to this message
Unread 02-17-2010, 06:25 AM   #47
crusher242
Get an old DJ, drop a 440 Mopar in it, and put a 60 in the rear with some big drag radials. There's your go fast jeep. I wish I had the time and money to do it....
Hold onto something... Quick!!!
crusher242 is offline   Reply With Quote Quick reply to this message
fast tj , performance , speed
