people with windshield lights - JeepForum.com
post #1 of 30 Old 06-30-2008, 07:55 PM Thread Starter
sleeperek9
Just seeing what you did with your antenna??? I have the KC slimlights and the windsheild brackets and no matter how far forward i put them the antenna hits the light.
sleeperek9 is offline
post #2 of 30 Old 06-30-2008, 08:01 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Be imaginative, just put a piece of electrical tape, shrink wrap, or put a small piece of vacuum hose like I did! I'ts going to hit it no matter what! It just won't have that metal on metal sound! Hope that helps?
GOLENJEEPTJ is offline
post #3 of 30 Old 06-30-2008, 08:04 PM
RobFromRI
i zip tied mine away from it. it works quite well...
1999 Jeep Wrangler TJ 4.0 5 Speed Chili Pepper Red
2003 VW GTI 1.8T 6 Speed
Jazz Blue 20th Anniversary Edition #3177 of 4000
RobFromRI is offline
post #4 of 30 Old 06-30-2008, 08:05 PM
TXjeepTJ
TXjeepTJ's Avatar
i did electrical tape lol... i like how it starts melting in the summer time
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #5 of 30 Old 06-30-2008, 08:06 PM
raskull
raskull's Avatar
Bend your antenna a bit by hand. A friend did a little bit of a jog in his kind of like this..
Worked out good, and looks almost stock.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #6 of 30 Old 06-30-2008, 08:06 PM
Jeepkid09
One thing I have been wondering about the windshield lights, do you get a bad glare off your hood?
Jeepkid09 is offline
post #7 of 30 Old 06-30-2008, 08:15 PM
dodgetk81
I bent mine tofollow the windshield frame
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #8 of 30 Old 06-30-2008, 08:35 PM
BK'sTJ
that's what i did, my buddy did the bottom bend but he left the top angled back and it followed the contour of the windshield, looks pretty cool too
Never forget that every day, to ensure your way of life; good men must do evil things
"I don't believe in repeat offenders, I believe in dead offenders." Ted Nugent
BK'sTJ is offline
post #9 of 30 Old 06-30-2008, 08:36 PM
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
I bent mine on my old TJ and my JK just like the pic... people think it's a custom antenna and ask where they can get one...
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #10 of 30 Old 06-30-2008, 09:01 PM
whitedevilish1
1979 CJ5
I bent my antenna also, & it works good. Just make sure you bend it towards the front or the back of the Jeep, I bent mine to the outside & it hit everything on the trails!
whitedevilish1 is offline
post #11 of 30 Old 06-30-2008, 09:04 PM
MoJeeper
2009 JK Wrangler
I just took mine off, With XM, Cd's I don't need it.
09 JKU Sahara
MoJeeper is offline
post #12 of 30 Old 06-30-2008, 10:14 PM
2005X
i left mine, hits it all the time, no biggie
2005X is offline
post #13 of 30 Old 06-30-2008, 10:27 PM
DemonDeacon
2014 WK
I did the electrical tape as well..works just fine... and yes i do get a glare off of the hood..KC makes light shields that may help. I dont know whether they do or not but it is an option.
DemonDeacon is offline
post #14 of 30 Old 06-30-2008, 10:52 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
bent it............
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #15 of 30 Old 07-01-2008, 04:53 AM
Neil F.
Mine is angled back. I drilled two small holes in the light bracket and used a tiny zip tie to keep the antena back. (The previous owner just let the antenna beat and scratch the hell out of the light.)
Neil F. is offline
Windshield lights --Glare on windshield? LGriffith Wrangler General Discussion 14 08-17-2009 08:50 AM
Windshield mounted lights, windshield down? Jblankster TJ Wrangler Technical Forum 5 07-25-2009 12:16 AM
who has windshield brackets for lights? Which lights? Stover954rr TJ Wrangler Technical Forum 15 06-09-2006 11:48 AM
Will Windshield Lights Work With the Windshield folded? MattTheMudder TJ Wrangler Technical Forum 12 01-18-2005 08:07 AM
Why are some people afraid of the square lights? franco802 TJ Wrangler Technical Forum 1 11-01-2003 12:42 AM
