penetrating oil study - JeepForum.com
post #1 of 96 Old 06-15-2010, 09:29 AM Thread Starter
03rubiconMG
So i have seen the results of the penetrating oil test (listed below) a lot of places but i have yet to see anything other than results and that they came from a magazine. Does anyone know what magazine? does anyone have a link to the actual source of the information?
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
2003 white rubicon on 37s
03rubiconMG is offline
post #2 of 96 Old 06-15-2010, 10:16 AM
SloppyJoseph
Intresting. I'd like to know also. Looks like we might be making up our own batch of oil.
SloppyJoseph is offline
post #3 of 96 Old 06-15-2010, 10:30 AM
Erik T.
Erik T.'s Avatar
WD-40 ain't a penetrating oil. It's a water displacement oil.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #4 of 96 Old 06-15-2010, 10:32 AM
mtn-grown
Cool. Proof that PB blaster is all hype (stuff sucks imo). Deep Creep for life!!
Caregivin' in the Rockies
mtn-grown is offline
post #5 of 96 Old 06-15-2010, 10:35 AM
jerseyjeep22
obviously its not all hype if it reduced the load by approximately half....while it may not be the best it is definitly better than others
jerseyjeep22 is offline
post #6 of 96 Old 06-15-2010, 10:36 AM
Erik T.
Erik T.'s Avatar
Kroil is groovy stuff. I don't think they make it in an easy to squirt can though.
-Erik.
Erik T. is offline
post #7 of 96 Old 06-15-2010, 10:39 AM
SloppyJoseph
They call it aerokroil. Check out their website. You can buy one can and get another one of their products for free. Im thinking about ordering some.
post #8 of 96 Old 06-15-2010, 10:56 AM
Jay12
yep saw it on my local jeep club forum and we have one guy that uses the ATF/acetone mix
Jay12 is offline
post #9 of 96 Old 06-15-2010, 11:26 AM Thread Starter
03rubiconMG
i have had very good luck with PB blaster although i dont doubt that there is better.
all WD 40 is good for in my opinion is to spray down 4 wheeler fenders during muddy races to keep the mud from sticking and weight down.
the 50/50 ATF Acetone makes me nervous, i feel as though if it drips on something other than a bolt such as a gasket or bushing it will corrode that if it gets the chance to sit.
I also like to be very very generous with this stuff so i dont like the idea of Kroil being over twice as much as PB blaster and Liquid wrench.
I want the original information so i can convince the mechanics at work to buy liquid wrench instead of PB blaster. (I spend a lot of time in the mechanic garage so i tend to use whatever they have)
post #10 of 96 Old 06-15-2010, 11:34 AM
Noxian
2011 JK Wrangler
Wow I have been buying Resolve Penetrating oil, its been ok, looks like i will have to try Liquid Wrench out
Noxian is offline
post #11 of 96 Old 06-15-2010, 11:34 AM
Dogman
Dogman's Avatar
Liquid Wrench looks to be the best bang for the buck. I'll have to try some out. I usually just use PB Blaster, but not too much problem with corrosion where I'm at.
John 3:17
Dogman is offline
post #12 of 96 Old 06-15-2010, 11:35 AM
Jay12
I use liquid wrench and it seems pretty decent when I use it
Jay12 is offline
post #13 of 96 Old 06-15-2010, 11:36 AM
AZJeepNewbie
I wonder about this too. The magazine widely attributed to this information is Machinist's Workshop Magazine. The only thing I've been able to confirm is that a magazine of that name does exist. But I've not been able to verify whether they published that data.
What I find strange is that no commercial company has even come close to the ATF-Acetone mixture, at least according to that table. So why hasn't anybody simply bottled that stuff and made a fortune on it? I find that suspicious.
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #14 of 96 Old 06-15-2010, 11:36 AM
Coils Rule
we use Wurth HHS2000 here at our shop and it's the cats meow.
Amazon.com: Wurth HHS-2000 Penetrating High Temperature Lubricant: Automotive
I would add that I got exhaust manifold bolts out of a 76 ford 460 engine after I tried everything under the sun at home. Then I brought this stuff home and slathered them for a week before I tried again and they broke free with relative ease.
Rockcrawlin' is lame.
Coils Rule is offline
post #15 of 96 Old 06-15-2010, 11:37 AM
Jay12
I copy/pasted the chart into google and it looks like this study came from Machinist's Workshop magazine
Jay12 is offline
penetrating oil test rudyyj TJ Wrangler Technical Forum 40 11-15-2010 07:41 PM
OEM Ball Joint Study ronjenx JK Wrangler Technical Forum 25 06-05-2010 11:12 PM
Another Recommendation for Penetrating Oil Older Fossil TJ Wrangler Technical Forum 9 05-29-2007 09:31 AM
Engine Oil Filter Study HotDogWater YJ Wrangler Technical Forum 1 10-09-2006 08:15 PM
Oil filter study pyro9862 YJ Wrangler Technical Forum 5 07-18-2005 12:39 PM
