Quantcast PDC Fuse Diagram - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > PDC Fuse Diagram
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 01-26-2009, 07:50 AM   #1
JeepJeffW
PDC Fuse Diagram
After doing a search here and via google I am still looking for a PDC fuse diagram for my 98 TJ. Only diagrams I can find are for the interior fuse assembly, anybody know where I can see the layout for the PDC under the hood?
JeepJeffW is offline   Reply With Quote
Old 01-26-2009, 08:42 AM   #2
Pillswoj
It should be printed on the inside of the cover.
Friends don't let Friends run Bosch
My Wifes Cake Site - Check the Jeep Under Carved & 3D
Pillswoj is offline   Reply With Quote
Old 01-26-2009, 11:38 AM   #3
JeepJeffW
Just a couple of the relays are listed there. Then it states "refer to owners manual" but there is nothing in the OM about the fuse layout.
Old 01-26-2009, 12:14 PM   #4
kloppk
Here is some info. I'm still looking for "what fuze does what".
Do you have a specific question such as to what does Fuze X protect or which fuze is for some circuit?
kloppk is offline   Reply With Quote
Old 01-28-2009, 03:32 AM   #5
JeepJeffW
I am curious about fuses 16 - 21. I've pretty much figured out the rest, thanks to your help, but not sure about these six fuses. I'll have to file this one away for future use. Thanks again!
Old 01-28-2009, 07:27 AM   #6
kloppk
PDC Fuze 16 - Fuel Pump Relay
PDC Fuze 17 - Under hood lamp, interior lights, ODBII power, radio, dome lamps
PDC Fuze 18 - ABS pump relay
PDC Fuze 19 - AC Compressor Clutch
PDC Fuze 20 - Horn
PDC Fuze 21 - Ignition Coil
HTH!
Glock Forum
