PCV valve help - JeepForum.com
post #1 of 10 Old 01-30-2008, 04:59 PM Thread Starter
ghanasjeep
PCV valve help
broke mine off, oil leaking, and pressures about 50 on the highway.
ghanasjeep is offline
post #2 of 10 Old 01-30-2008, 05:01 PM
Zlake
Zlake's Avatar
The PCV "Valve" isn't really a valve but just an elbow. Anyways you can get it from your local dealer for about $5. I did yesterday
Zlake is offline
post #3 of 10 Old 01-30-2008, 05:28 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Yup,what he said.
TheBoogieman is offline
post #4 of 10 Old 01-30-2008, 05:54 PM Thread Starter
ghanasjeep
thanks guys, so how nessesary is it?
post #5 of 10 Old 01-30-2008, 08:18 PM
Michael_K
Michael_K's Avatar
Depending on which one you broke off, it could cause high idle at around 2000rpm.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #6 of 10 Old 01-30-2008, 08:19 PM
Mike
oooh you almost had it
Mike's Avatar
oil "blow-by"
Mike is offline
post #7 of 10 Old 01-30-2008, 09:25 PM Thread Starter
ghanasjeep
oils out of the bottom. kinda looks like its out of the rear main
post #8 of 10 Old 01-30-2008, 09:32 PM
Rubixcube
The pcv valve is a valve... Its a check valve that lets positive crankcase presure into the intake so there is no oil lost on the groung like the old days. its e.p.a. crap. The reason for the high idle when it breaks is its causing a vacume leak. It's a inexpensive part and would not be a bad idea to fix it.
Rubixcube is offline
post #9 of 10 Old 01-30-2008, 10:02 PM
Zlake
Zlake's Avatar
I think that you will have a hard time finding a PCV "valve" for this. I tried unsuccessfully because, as I later learned, it isn't a valve. I know what a PCV valve is and what it does and this is not a valve. Just because this one on TJ's is not does not mean that the PCV Valves in other applications are not valves. I argued it with the dealership and they had to show me I was wrong and that it really wasn't a valve....lol.
Part number: 53030495 price: $6.10
Zlake is offline
post #10 of 10 Old 01-31-2008, 06:47 AM
mschviuz
Been there myself at the local parts store. I was told there isn't a pcv valve to which I argued and guess what....I was wrong. I checked myself by blowing air into the tubes...guess what....air flows each direction on those....just elbows.
I felt stupid
mschviuz is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-29-2012 12:07 AM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
EGR valve help cableguy01960 YJ Wrangler Technical Forum 1 10-28-2008 10:20 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 04:33 PM
pcv valve? genakab TJ Wrangler Technical Forum 6 02-24-2006 08:05 AM
