pcm swap? - JeepForum.com
post #1 of 3 Old 07-09-2010, 06:34 PM Thread Starter
porforkid
pcm swap?
my buddies 2004 tj 4.0 auto wont start and weve done just about everything to our ability to try and fix it. we think it could be a fried pcm. would it be a bad idea to try and unbolt my 99's pcm which is a 4.0 manual and put it in his to see if it would fire up or would this be a complete disaster?
porforkid is offline
post #2 of 3 Old 07-09-2010, 06:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The ignition system alone is way different between '99 and '04, I doubt it would work.
Jerry Bransford is offline
post #3 of 3 Old 07-09-2010, 08:55 PM
kdukes4
with a pcm, i think everything has to match up, even down to the vin??? i blew the voltage regulator in my '97, jerry remembers this one, long story short, i went the route of replacing the pcm after a temporary fix of putting a regulator on the alternator. anyways, i don't think you can take just any other pcm, its really got to be specific i think. i found a place in FL, i paid $180 i think, sent them my model, year, vin, trans type etc. a couple days later pcm was at the door step, two minute swap and everything was a go. just have to send them back your busted pcm and you get a lifetime warranty on the product. much cheaper than spending $700-1k at the dealership.
'04 tj, Outboarded
kdukes4 is offline
pcm , swap , troubleshoot , fix
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
