Pattern check D44 Rubi regear - Page 2 - JeepForum.com
post #16 of 26 Old 09-18-2011, 11:26 PM
dcope17
Originally Posted by RubiconRazorbac View Post
Bull****. There's plenty of folks around that can give great advice on a gear pattern.
It just may take more than a couple if hours for them to respond on a Sunday afternoon.
Sorry... except for the "extreme novice regear" thread... I haven't seen much on people setting up gears here. I don't look at pirate very often... just seemed more likely to find there.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #17 of 26 Old 09-19-2011, 03:39 PM
joe_jeep
you could try posting it on gl4x4 also. slightly smaller than pirate, but some decent guys that know gears.
good luck
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #18 of 26 Old 09-19-2011, 06:21 PM Thread Starter
jr03
New Pattern Pictures, comments please
.008BL Pinion .055 RGS.138 Nrgs.138
jr03 is offline
post #19 of 26 Old 09-19-2011, 06:22 PM
jampop1
much better
jampop1 is offline
post #20 of 26 Old 09-19-2011, 07:08 PM
pcoplin
pcoplin's Avatar
Pattern looks real good. I'd run it.
pcoplin is offline
post #21 of 26 Old 09-20-2011, 11:11 AM Thread Starter
jr03
Thanks, once I get this finished up its on to the rear axle.
jr03 is offline
post #22 of 26 Old 09-20-2011, 11:17 AM
2ACR
That's Right I Support
2ACR's Avatar
Looks great. Wish I had the time to do mine. What did you do to get your pinion preload?
Originally Posted by jr03 View Post
And when you can't find the wrench your holding in your hand, it's time for a break:rofl:
Jeep Jedi in Training.
2ACR is offline
post #23 of 26 Old 09-20-2011, 11:36 AM Thread Starter
jr03
I just installed the outer thrust washer and tightened the yoke nut until I reached the preload for setting up, I still need to remove the setup race, install preload shims and check/adjust as needed. For pinion load for taking the pattern, I twisted a towel and wrapped it around the yoke and held it while I turned the carrier with a closed end wrench. That's what worked for me to get the most consistent load for taking a pattern. This is my first time doing this, I think the first axle is the hardest because your learning the mechanics of everything, after that its lots of patience and measuring and developing a feel for how much one shim change changes the tolerances(I've a long way to go yet...writing stuff down as you go is a big help)
jr03 is offline
post #24 of 26 Old 09-20-2011, 11:54 AM
2ACR
2ACR's Avatar
We are about in the same boat. I still can't feel my way around the job like some can and I am constantly going through the directions my buddy gave me to make sure I did everything correctly. I'm going to do an empty front 44 when I get the chance. It kind of scares me since I won't have a starting point.
Where did you get your instructions or where you like me and had some hand written stuff?
2ACR is offline
post #25 of 26 Old 09-20-2011, 12:55 PM Thread Starter
jr03
I used http://www.pirate4x4.com/tech/billavista/Gear_Setup/ as well as the writeups here, the novice regear thread and links in there to a couple of D44 regears. Yukon also has a PDF on setup. The two D44 write ups I saw setup around .041-.043 if I remember. Good tools make life easier and less frustrating too. And when you can't find the wrench your holding in your hand, it's time for a break
jr03 is offline
post #26 of 26 Old 09-20-2011, 02:21 PM
2ACR
2ACR's Avatar
Can't tell you how many times that has happened to me.
2ACR is offline
Hows my gear pattern? D30 regear. rs4race TJ Wrangler Technical Forum 11 04-02-2010 04:15 PM
Dana 30 Regear in progress - Contact pattern sequel YJ Wrangler Technical Forum 3 01-23-2010 02:54 PM
Rubi D44 Regear options for Tru-Lok npsrubicon TJ Wrangler Technical Forum 6 08-13-2009 09:44 PM
33" on Rubi, regear? fire814 TJ Wrangler Technical Forum 39 12-16-2007 12:02 PM
