passenger side airbag disable - JeepForum.com
post #1 of 13 Old 04-18-2010, 05:32 AM Thread Starter
greta
my first tj (2000) was a bone stock that had a on/off switch for passenger airbag.
my current tj (2004) is fully loaded however does not have a passenger on/off switch.
i would like to be able to disable it for the young one.
i have read some threads about putting in sim switch for passenger airbag after disconnecting it but it kind of seems like a pain...
on this thread http://www.jeepforum.com/forum/f9/di...25/index2.html someone mentioned that the dealership was required to add a disable switch... anyone know if this is true?
greta is offline
post #2 of 13 Old 04-18-2010, 08:47 AM
sstaurus
sstaurus's Avatar
Wish I could help you.. I just wanted to comment I find it odd they removed the ability to do that... perhaps legal reasons with people forgetting to turn it back on? I know most new cars have a weight sensor in the passenger seat now...
'02 Sienna Pearl TJ Sahara
sstaurus is offline
post #3 of 13 Old 04-18-2010, 11:11 AM
Jonny Jeep
Jonny Jeep's Avatar
The passenger airbag switch was only required to be fitted in Jeeps sold without a back seat.
No reason you can't fit one though. If you can't get a new switch there are plenty on ebay and you could try places like D A V E Y S J E E P S . C O M - Parts Specials
Jonny Jeep is online now
post #4 of 13 Old 04-18-2010, 11:17 AM
Cesaros
remove whatever fuse controls it? You may run the risk of disabling both airbags...but it may be worth looking into.
Cesaros is offline
post #5 of 13 Old 04-18-2010, 11:18 AM Thread Starter
greta
you don't by any chance have an idea how i would go about fitting one do you?
obviously i would have to get the switch, but do you think that there is an unused harness just waiting to be used or would this be one of those deals where there is a lot of wire hacking going on?
greta is offline
post #6 of 13 Old 04-18-2010, 11:19 AM Thread Starter
greta
your exactly right. by disabling the two fuses it kills both airbags. plus i am pretty sure that it would provide a constant check engine light as well.
greta is offline
post #7 of 13 Old 04-18-2010, 11:42 AM
ohtenwillys
no check engine light.. just the airbag light.. i removed the airbag module too anyway.. im so surprised i didnt get a punch in the face when i hit a rock too hard
ohtenwillys is offline
post #8 of 13 Old 04-18-2010, 11:51 AM
Jonny Jeep
Jonny Jeep's Avatar
Looking at the wiring diagrams and connector locations, the connector should be there for it, so you'd simply have to buy one and fit it. Hopefully someone who has done this will pop along and state if it is as easy as it would seem.
post #9 of 13 Old 04-18-2010, 02:35 PM Thread Starter
greta
thanks friend
greta is offline
post #10 of 13 Old 04-18-2010, 02:38 PM Thread Starter
greta
i am not positive but i think that i read that you have to be going so fast for the airbag to even deploy regardless of how hard you hit something.
i am sure someone will come along and correct me if i am wrong.
as for d/c'ing both AB's... i may try that, however i would like to explore the option of installing a switch first as that seems more sensible.
greta is offline
post #11 of 13 Old 08-22-2010, 08:10 AM
nidus72
Any follow-up info on this item? I have a 2003 TJ Sport without the switch and I'm interested in getting one and trying to install it. I've read somewhere else that you need the switch as well as some module behind the glovebox? Any updates would be appreciated.
Nidus72
nidus72 is offline
post #12 of 13 Old 08-22-2010, 06:14 PM Thread Starter
greta
no updates yet... i am still interested in doing it if you figure out how to though. there are some threads that said that the module in the glovebox is already there because all cars made after 199? required them by law... not sure if that is true though.
i took my dash off to see if it was already pre-wired for a switch; it wasn't...
i am a little hesitant to start splicing wires to the airbag system.
unless i can find a idiot-proof method of doing it then i will likely end up pulling the fuses or taking it to the dealer or adding it to the lists of things that i always wanted to do but never did
greta is offline
post #13 of 13 Old 08-22-2010, 07:45 PM
marc1kim
My SE had the airbag switch. Backseats were optional for the SE. Im looking for the answer as well
05 LJ
08 JKU Rubicon
marc1kim is offline
How to disable the passenger side airbag snccoulter TJ Wrangler Technical Forum 26 03-30-2012 12:15 PM
passenger airbag disable? monkeychrist TJ Wrangler Technical Forum 6 08-23-2007 07:20 PM
disable airbag warning light / passenger side only gethin TJ Wrangler Technical Forum 1 06-19-2007 12:07 PM
Passenger side airbag disable cutt JK Wrangler Technical Forum 2 12-04-2006 06:16 PM
Disable passenger airbag? Mastiff TJ Wrangler Technical Forum 1 01-18-2006 12:22 PM
