Passenger door handle - JeepForum.com
post #1 of 12 Old 03-06-2007, 04:20 PM Thread Starter
Wrigley
My passenger door handle is actually coming out of the door. The "box" that the handle is in is loose and pops out of the door frame at times. 2006 Unlimited. ??
Mike
Wrigley is offline
post #2 of 12 Old 03-06-2007, 04:31 PM
sccabrian
You an either take apart the door yourself and possibly void the warranty on the door, or take it in. I would take it in for that problem, it doesn't quite sound right. Could be an easy fix for for someone who's taken them apart before though.
sccabrian is offline
post #3 of 12 Old 03-06-2007, 06:09 PM
ChuckDee
There's two wedge type pieces of metal that hold it in on either side. I'll bet one or both are laying in the bottom of your door somewhere. They're a pain-in-the-_$$ to get in (and out). If you have a little time and patience, and can find the pieces, you can surely fix it. See the write-up HERE regarding painting the door handles to see how they are secured.
Previously owned: 2001 TJ Sport
ChuckDee is offline
post #4 of 12 Old 03-06-2007, 06:11 PM
Rocky529
Rocky529's Avatar
As mentioned, the handle is wedged in with 2 key like metal pieces. You need small hands to fix it, but the dealership will fix it for you for free under warranty.
Personally, I would take apart the door and fix it myself.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #5 of 12 Old 03-06-2007, 07:44 PM Thread Starter
Wrigley
Does the inside panel on the door come off?
Mike
Wrigley is offline
post #6 of 12 Old 03-06-2007, 07:47 PM
rayar3
If Jeeps could fly...
rayar3's Avatar
Don't try to fix it yourself!!!
I had this happen too. Took it in for work and they said the screws or something were loose and they tightened them. 2 weeks later and it happend again.
They ended up having to replacing the entire pax handle assembly, which is what I'd suggest you have them do from the start. Dealership I go to is very friendly when I've brought in warrentee work, even though I bought the Jeep somewhere else for cheaper than they were!
2000 XJ 2-door (current)
2006 65th Anniversary TJ (sold)
rayar3 is offline
post #7 of 12 Old 03-06-2007, 07:48 PM
Rocky529
Rocky529's Avatar
Mike
Yea, you have to remove the window crank (c-clip), and then the rest is easy.
Rocky529 is offline
post #8 of 12 Old 03-06-2007, 07:50 PM
bairy
Same thing is happening to me(same side too)!! 2006 unlimited. It bothers the crap out of my wife. I figured I would take in under warranty when the weather is nice enough to just leave them with the door.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #9 of 12 Old 03-06-2007, 07:54 PM
rayar3
rayar3's Avatar
I did the same thing the first time I brought it in...just left the door. The kid that did the work said that if he needs to do this again (and he did 2 weeks later) he won't suggest it. They had to pull a new jeep off the lot and mount my door on it so they could work on it and test it.
The thing I didn't like about it being loose was water and dirt getting inside the door. I'd get it fixed, it took less than half a day when they preordered the new handle.
rayar3 is offline
post #10 of 12 Old 03-06-2007, 08:28 PM Thread Starter
Wrigley
Ray,
I'm in Jax. Which dealership do you go to?
Mike
Wrigley is offline
post #11 of 12 Old 03-06-2007, 08:56 PM
rayar3
rayar3's Avatar
I take it to Jacksonville Chrysler Jeep Dodge off of 9A and Baymeadows. It's a huge dealership, and I don't remember the name of the girl I deal with. When you drive in, you bear to the left for service. They do good body work too (where I took it to after someone rearended me) I'd suggest calling before you get there, as they are usually busy. I'm guessing that they'll look at it and try to fix it first just like mine.
I bought the Jeep up in Yulee, but it's too far of a drive for me if I need work done.
rayar3 is offline
post #12 of 12 Old 03-07-2007, 01:45 PM Thread Starter
Wrigley
I bought mine at Mike Shad on Cassat. I have taken it 3 times to Jacksonville Chrysler Jeep Dodge off of 9A for various warranty work and I am NOT impressed with their service department at all.
Mike
Wrigley is offline
TJ passenger grab handle question samger2 TJ Wrangler Technical Forum 3 07-16-2008 10:09 AM
Passenger Grab Handle Rokitt JK Wrangler Technical Forum 24 04-26-2007 10:20 PM
Passenger side Inner door handle installation ....broke a new one already !! sunny_8 YJ Wrangler Technical Forum 6 09-22-2005 03:17 PM
passenger side door handle (inside) drorez TJ Wrangler Technical Forum 4 10-01-2004 10:16 AM
Passenger side interior door handle question? BOTLFED98 YJ Wrangler Technical Forum 6 11-11-2003 09:55 PM
