Passenger brake light won't work - JeepForum.com
post #1 of 3 Old 10-26-2012, 12:00 PM Thread Starter
yancey2112
I recently replaced the tail light on the passenger side. No matter how I played with the wiring and can't seem to get everything working correctly. When I press the brakes, the light is dim as if the running lights were on. When I turn the running lights on, the light is brighter as if the brake was being pressed.
Anyone have a suggestions?
I've ordered a new flasher cause I put LED's on the front, so I won't know about the turn signals til that's replaced.
Also, I noticed that the wires for trailer lights had been cut or torn by the PO, could that have something to do with it?
Thanks guys
A.E.K.D.B. Go Noles!
"I saw a werewolf drinking a Pina Colada at Trader Vic's. His hair was perfect."
yancey2112 is offline
post #2 of 3 Old 10-26-2012, 12:15 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That could be nothing more than a bad electrical ground connection for the bulb enclosure. The rear tail lights are grounded via the three screws that hold the housing to the tub. I would remove all three screws and wire brush them and what they screw into, then solidly reinstall them.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #3 of 3 Old 10-27-2012, 05:00 AM
Jonny Jeep
Jonny Jeep's Avatar
running light bright + brakes light dim = bulb forced in the wrong way round, or tail light wired incorrectly.
Jonny Jeep is online now
brake lights , help needed , tail lights , tj , wiring
