Part Number for Light Switch? - JeepForum.com
post #1 of 8 Old 01-28-2009, 03:30 PM Thread Starter
IH8ROADZ
I need a part number or where I can get a light switch for a 99 TJ. Not the column mounted one but the dash mounted one with the pull/push light switch. All my gauge lights are out and all the wires seem to be fine so Im guessing it's somethign internal on the switch.
IH8ROADZ is offline
post #2 of 8 Old 01-28-2009, 03:31 PM
robncar
robncar's Avatar
You've checked the fuses, right?
SWITCH, Headlamp 56009869AB
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 8 Old 01-28-2009, 03:52 PM Thread Starter
IH8ROADZ
which fuses need to be checked? Any under hood?
IH8ROADZ is offline
post #4 of 8 Old 01-28-2009, 05:16 PM
robncar
robncar's Avatar
Under the hood in the PDC and, more likely, the fues behind the glove box inside the vehicle. A $10 Radio Shack meter is a great investment for this kind of thing.
robncar is offline
post #5 of 8 Old 01-28-2009, 06:37 PM
remote1
if i remember correctly there aren't any fuses for the '99, switch has a circuit breaker built into it, i recently put a switch in for a friend got it from quadratec worked well. i think it was $45 shiped
remote1 is offline
post #6 of 8 Old 01-28-2009, 07:27 PM
kloppk
Incorrect.. There are fuses for the headlights.
There is also a 24 amp circuit breaker built into the headlamp switch.
edit: Corrected
kloppk is offline
post #7 of 8 Old 01-28-2009, 08:08 PM Thread Starter
IH8ROADZ
How do you reset the circuit breaker?
IH8ROADZ is offline
post #8 of 8 Old 01-29-2009, 01:43 AM
Jonny Jeep
Jonny Jeep's Avatar
Fixed it. Fuse 1 in the glove box fuse panel works the marker and dash lamps. The circuit breaker is not for that circuit, it's only for the dip/main beam lights. Fuse 1 (fuse box) gets power from fuse 4 (PDC). fuse 4 also supplies fuse 2 in the fuse box (stop lamps). The dip/main headlamps get power from fuse 10 in the PDC which goes to the circuit breaker in the headlamp switch.
Originally Posted by Jonny Jeep View Post
I'd pull fuse 1 from the panel behind the fuse box and check it properly if you've not already pulled it. If the fuse is OK you may have a problem with the head lamp switch, or the wiring from the fuse panel to the switch. Check for live at the tan/black wire which is the feed from the fuse. The outputs for the external and dash lights are on different wires so I expect the problem is with the supply side.
Jonny Jeep is offline
Mucket Seal part number question (rubber part on door surrounds) commodog TJ Wrangler Technical Forum 6 07-12-2009 07:50 PM
Need part number - plug to neutral safety switch SoonerE39 TJ Wrangler Technical Forum 9 11-27-2008 08:17 AM
Fan Speed Control Switch Part Number? Oman Jeep TJ Wrangler Technical Forum 0 08-28-2008 11:20 AM
4wd dash light - what part number newcaddy4j TJ Wrangler Technical Forum 1 10-02-2006 01:59 PM
Part Number for Light Bulbs? NIUPonyBoy YJ Wrangler Technical Forum 6 10-30-2003 06:35 AM
