P1294 (Target Idle Speed Not Reached) Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > P1294 (Target Idle Speed Not Reached) Help
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 10-14-2010, 09:29 PM   #1
JustChillin
I just checked the error code and it read P1294. Is this really bad? I have to drive 250 miles back home tomorrow. Can I put off fixing it until I get home?
JustChillin is offline   Reply With Quote Quick reply to this message
Unread 10-14-2010, 09:37 PM   #2
Broncbuster
You will be fine driving it. The only thing is the idle will not drop down as quick when you let off the gas- usually idles high. I would bet it's the IAC causing it. Cheap and easy fix. 2 torx screws and a plug in that can be accomplished in about 5 minutes.
Broncbuster is offline   Reply With Quote Quick reply to this message
Unread 10-14-2010, 09:40 PM   #3
JustChillin
thanks. thats a relief. i got something to do this weekend!
Unread 10-14-2010, 09:52 PM   #4
fishinjeeper
http://www.jeepforum.com/forum/f9/cl...mmies-1114849/
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER]
fishinjeeper is offline   Reply With Quote Quick reply to this message
Unread 08-25-2011, 09:06 AM   #5
DannyO2377
P1294 (M) Target Idle Not Reached
Target RPM not achieved during drive idle condition. Possible vacuum leak or IAC (AIS) lost steps.
Listening to the jeep, I now hear a "Whistling" noise since I got the P1294 code. Does this mean I have a vacuum leak and probably NOT an IAC problem?
Thanks,
Danny O
DannyO2377 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2011, 03:23 PM   #6
lope
lope's Avatar
You can check for a vacuum leak by having the engine running and spraying carb cleaner at various spots on/around engine, especially intake and vacuum hoses etc. and listening for changes in engine idle. If you spray and the engine revs up a bit you've found where the vacuum leak is at it suck in the carb cleaner.
lope is offline   Reply With Quote Quick reply to this message
Unread 02-17-2012, 08:29 PM   #7
rubicon1983
http://i40.tinypic.com/2ni9vli.jpg removed whole throtle body and i cleaned myn With carb cleaner then installed spacer checked leaks cleared code works wicked
rubicon1983 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2012, 04:13 PM   #8
rubicon1983
Well scratch that i checked for leaks put new throttle body spacer gaskets cleaned map tps and iac with proper cleaner 2 times and just comes back p1294 i read every forum post and i have no frigging clue im ready to go buy all new body and map iac tps i guess anyone know/ideas look at my pic plz thks
Unread 02-23-2012, 04:14 PM   #9
rubicon1983
deleted
Unread 02-25-2012, 09:28 AM   #10
JustChillin
I ended up adjusting the throttle a bit. It's not recommended, but it worked. Every now and then I get the code when a cold front comes in.
Unread 02-29-2012, 06:18 PM   #11
rubicon1983
yeah i changed iac sensor but not the housing goes away comes back still starts better but still not idling right i cleaned everything. what is the hose that goes from rear pcv valve to the manifold behind the throtle body anyone know i sprayed that rpms goes up think thats the prob or the intake exaust manifold/ headers i bought set banks going to install see if thats the prob anyone got part number for the vacum hose rear pcv to manifold
Unread 11-26-2013, 11:30 AM   #12
JeeperTJ19
This has happened to me a twice and both times it was the intake manifold gasket! Try spraying carburator cleaner at the gasket if it starts to low idle or die than that's the problem just another thing to think about!
JeeperTJ19 is offline   Reply With Quote Quick reply to this message
Unread 08-31-2014, 02:14 PM   #13
ecarr2
I'm getting the same code and I have no idea what to do.
I put a new IAC valve and TWO new TPS sensors in because it seemed that the first one that I bought was junk, then rewired the crappy wiring that I found behind the TPS so that its really clean now. I also took off the throttle body and cleaned everything... sprayed carb cleaner to look for vacuum leaks and got no change in idle whatsoever so I dont think its a leak.
Right now I have the new TPS disconnected from the throttle but still plugged in and im getting a 6.7% reading on the computer.. shouldnt it be zero if its not actually connected to the throttle? I just put this TPS in - if its reading high, could I somehow have another junk one or is it maybe an ECU problem? Im totally at a loss at this point.
Help a girl out, please!
ecarr2 is offline   Reply With Quote Quick reply to this message
