P1294 (M) Target Idle Not Reached - JeepForum.com
post #1 of 4 Old 08-25-2011, 09:08 AM Thread Starter
DannyO2377
Target RPM not achieved during drive idle condition. Possible vacuum leak or IAC (AIS) lost steps.
Listening to the jeep, I now hear a "Whistling" noise since I got the P1294 code. Does this mean I have a vacuum leak and probably NOT an IAC problem?
Thanks,
Danny O
DannyO2377 is offline
post #2 of 4 Old 08-25-2011, 09:30 AM
freeskier93
Yes, most likely vacuum. Check connections on the intake manifold. You can also take water and spray it around, you'll know where the leak is because the engine will bog down.
freeskier93 is offline
post #3 of 4 Old 04-11-2012, 04:29 PM
indeliblejeep
Target idle not reached?
I'm having the same problem, I've been trying all sorts of S***, I've tried new hosing on the intake, new throttle body, cold air intake and nothing really seems to be doing it!!! if you have any suggestions on what fixed yours I'd really appreciate it. I'll share too when i find a fix.
indeliblejeep is offline
post #4 of 4 Old 04-11-2012, 06:33 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you checked the line going to the vacuum reservoir under the battery tray?...
Knuckelhead is offline
P1294 (Target Idle Speed Not Reached) Help JustChillin TJ Wrangler Technical Forum 13 01-16-2016 06:03 PM
Cracked exhaust manifold=P1294 code? Jacola11 TJ Wrangler Technical Forum 0 07-18-2011 09:25 AM
97 2.5L, 1500 rpm idle, P0320, P1294? autopc25 TJ Wrangler Technical Forum 14 07-17-2011 10:47 PM
PLEASE HELP. P1294 Fuel air (iac) Problem tjchris3 TJ Wrangler Technical Forum 4 01-08-2008 10:42 PM
P1294 ADub07 TJ Wrangler Technical Forum 5 12-18-2007 05:40 AM
