P0442, P0455 error codes, help please - JeepForum.com
post #1 of 8 Old 09-25-2006, 03:57 PM Thread Starter
zamora3
The check engine light keeps coming on and off as it pleases and those codes keep coming up when I do the 3 key turn trick. What do they mean? I think I remember reading that the P0455 was due to the fact that the gas cap wasnt on right. But if thats the case, then why would the check engine light come on when I'm driving on the highway? Any help at all would be greatly appreciated. Thanks guys.
2004 Rubicon I6 Soft Top
zamora3 is offline
post #2 of 8 Old 09-25-2006, 05:08 PM
plumcrazy
plumcrazy's Avatar
http://www.obdii.com/codes.html
'01 Sahara, OME 2.5, 1" BL/MML, 33x12.50x15 BFG A/T tires on Aluminum American Racing rims, XM radio.
NOW i gotta figure out how to get more HP ! ! !
plumcrazy is offline
post #3 of 8 Old 09-25-2006, 05:10 PM Thread Starter
zamora3
Thanks for the link. So are they both dealing with a loose gas cap or might there be something else?
zamora3 is offline
post #4 of 8 Old 09-25-2006, 05:11 PM
Remoot
Remoot's Avatar
2005 WK
http://www.jeepforum.com/forum/showt...threadid=23788
442 A leak has been detected in the evaporative system
455 A large leak has been detected in the evaporative system
Ma pole midagi valesti teinud
Remoot is offline
post #5 of 8 Old 09-25-2006, 06:04 PM
xtremebikr04
I have the same problem on my 01 and i have changed the gas cap, then cleared the code and it came back again.
xtremebikr04 is offline
post #6 of 8 Old 09-25-2006, 11:23 PM Thread Starter
zamora3
so basically there is nothing to worry about or what?
zamora3 is offline
post #7 of 8 Old 09-25-2006, 11:41 PM
hazmat
an evap leak is a pita to diagnose if it's not your gas cap or a blatant crack or hole. my shop got a 3500 dollar snap on smoke machine because of all the evap work we were getting. I'd recommend a dealer or a well equipped shop if you know one.
hazmat is offline
post #8 of 8 Old 09-25-2006, 11:47 PM
The_'ster
An '04 rubi shouldn't that still be under warranty? There are several things that can flag those codes. Most often it's a loose or poor sealing gas cap. Other things could be a leaking/sticky valve on the canister valve, purge valve, or any other valves they put in the system. Also a faulty fuel tank pressure sensor, if so equiped, or a leaking canister or hoses. Every vehicle is different, and there are many designs of onboard leak detection. Just throwing parts at it is not the answer. It won't damage anything to drive it; it's a way for the vehicles to recycle the fuel vapors in the tank rather than venting it to the atmosphere.
'98 TJ has been under the knife the last 30 months getting a new frame, torque boxes and fenders.
The_'ster is offline
P0442 and P0455 noleswin TJ Wrangler Technical Forum 4 11-29-2011 09:35 PM
Error Code P0442 blackattak TJ Wrangler Technical Forum 6 10-24-2008 10:55 AM
Error codes P0455 & P0442 JeepGirl04 TJ Wrangler Technical Forum 6 07-12-2008 10:52 AM
P0442 error code... PearlJam1003 TJ Wrangler Technical Forum 6 12-29-2007 12:24 AM
p0442 error code Mindvirus TJ Wrangler Technical Forum 4 10-15-2007 07:21 AM
