P0301 and P0300 Codes. running out of crap to change - Page 2 - JeepForum.com
post #16 of 20 Old 10-03-2010, 07:42 AM
Dryseals
1980 CJ7
Originally Posted by RMiksits View Post
Still have not figured this out. Ive taken it to 4 different mechanics now all say its running fine.
WTF? this may be an excuse for a new engine.
Got rid of the p300 now its only p301.
What on earth would cause only cylinder 1 to misfire?
Injector, valve spring or spark plug...agreed.
The position sensors measures time. That is if your spinning at 2500 RPM then the time between sensor reads is going to be so many milli secounds all the time. If you get a misfire, that time span is a few milli seconds longer. And the computer reports that as a misfire.
Any decent shop with the correct tools could narrow is down in a few minutes. If it's a bad spark, you should see O2, rich mixture, unburnt fuel. If it's no fuel then O2 would go lean. Being random and on the same cylinder, you should start looking closely at the connections there.
Dryseals is online now
post #17 of 20 Old 10-03-2010, 10:58 AM
gensysmike
Read through this service bulletin on valve carbon buildup and see if it might apply.
SUBJECT:
4.0L Multiple Cylinder Misfire
OVERVIEW:
This bulletin involves inspection of all engine exhaust valves and a decarbonizing
procedure if necessary.
MODELS:
1999 - 2004 (WJ) Grand Cherokee (All Markets)
2001 - 2004 (WG) Grand Cherokee (International Markets)
1999 - 2004 (TJ) Wrangler
1999 - 2001 (XJ) Cherokee
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A
4.0L ENGINE (SALES CODE = ERH).
SYMPTOM/CONDITION:
The customer may experience an incident of engine misfire during certain vehicle
operating conditons. The misfire may occur when the vehicle is operated between
80 - 112 KPH (50 - 70 MPH) and under light loading conditions, e.g. slight uphill
road grades. This condition may occur at all ambient conditions, but is more
noticeable when ambient conditons are less than 0 C (32 F).
If the vehicle is equipped with On-Board Diagnostic (OBD), a MIL illumination may also
have occurred due to Diagnostic Trouble Code (DTC) P0300 - Mulitiple Cylinder Misfire.
Various single cylinder misfire DTC's may also be present. If the frequency of misfire is
high the Powertrain Control Module (PCM) may place the engine in "Limp-In" mode.
The misfire condition may be caused by one or more engine exhaust valves that are
slow to close. Late closure of an exhaust valve may be the result of no valve rotation
and associated build up of carbon on the exhaust valve stem.
DIAGNOSIS:
1. This condition may occur when the engine is not allowed to run at engine RPM's that
are greater than 3,200 RPM. At 3,200 RPM or higher the engine exhaust valves
will rotate if not impeded by high carbon deposits. Low engine RPM's and high
carbon deposits are associated with short trip driving where the vehicle engine is
not allowed to fully warm to normal engine operating temperatures. Cold ambient
temperatures will increase engine warm-up time and add to the opportunity of
carbon deposit build-up on the stem of the engine exhaust valve.
2. Verify that an engine misfire condition is present. Use of the DRBIIIŽ during a road
test, or a Co-Pilot data recording, may help to determine engine misfire and misfire
counts. If carbon deposit accumulation is severe, then a cylinder leak down test
may detect one or more cylinders leaking greater than 15%. Save any misfire DTC
Freeze Frame Data that was stored for later misfire correction verification.
3. Verify that the engine misfire condition is not caused by faulty engine
mechanical or electrical components.
4. If the engine mechanical and electrical systems are operating properly
perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 04318001AB Mopar Combustion Chamber Cleaner
EQUIPMENT REQUIRED:
MD-998772A Valve Spring Compressor and Removal Essential Tool
REPAIR PROCEDURE:
INSPECTION:
1. Raise vehicle hood.
2. Remove the engine valve cover and all six exhaust valve rocker arms (the intake rocker
arms are also removed during this step). Refer to the appropriate vehicle Service
Manual for detailed removal instructions. The valve cover gasket is reuseable. Keep
each pair of rocker arms matched to their respective valve and cylinder.
3. Inspect the end, or tip, of each exhaust valve stem where it makes
contact with the respective rocker arm.
4. Determine if each exhaust valve is rotating within its respective valve guide. An
exhaust valve that is rotating will have a "bulls eye" or circular wear pattern on the
face of the valve stem tip. If the exhaust valve is not rotating a straight mark-like
pattern will be present across the face of the valve stem tip.
5. If there are exhaust valves which are not rotating then proceed to the VALVE
ROTATION section of this Repair Procedure.
6. If all exhaust valves are rotating, then this bulletin does not apply and further
diagnosis is required. Install the engine rocker arms and valve cover. Refer to the
appropriate vehicle Service Manual for detailed installation instructions.
VALVE ROTATION:
1. If one or more engine exhaust valves are not rotating, perform the valve
rotation procedure to all six (6) exhaust valves.
NOTE: IT IS IMPORTANT THAT THE VALVE ROTATION SECTION OF THIS
REPAIR PROCEDURE BE PERFORMED.
2. Clean and mark the tip of each exhaust valve stem with a paint marker. The paint mark
will be used later to assist with determining if the exhaust valve has been rotated 90 .
3. Bring number one (#1) cylinder piston to top dead center using the mark on the
crankshaft front dampener/pulley. This step is important to prevent the possibility
of the exhaust valve from falling completely into the cylinder.
4. Install the essential service tool valve spring compressor, MD-998772A,
to the #1 cylinder exhaust valve spring.
NOTE: THE FOLLOWING VALVE ROTATION PROCEDURE WAS DEVELOPED WITH
THE USE OF VALVE SPRING COMPRESSOR TOOL MD-998772A. THE MD-998772A IS
AN ESSENTIAL SERVICE TOOL AND PART OF THE DEALERSHIP REQUIRED TOOLS.
THE MD-998772A COMPRESSOR ENGAGES THE ENTIRE PERIMETER OF THE
VALVE SPRING RETAINER, UNLIKE OTHER MAKE VALVE SPRING COMPRESSORS.
5. Compress the #1 cylinder exhaust valve spring enough to gain access so that
the exhaust valve can be rotated 90 . Rotate the exhaust valve 90 . Slowly
remove the compression on the exhaust valve spring. Verify that the valve keeper
is properly seated to the valve stem and valve spring retainer.
6. The 4.0L firing order is 1 - 5 - 3 - 6 - 2 - 4. Without rotating the engine
crankshaft repeat steps 3 through 5 to cylinder #6.
7. Rotate the engine crankshaft 120 and repeat steps 3 through 5 to cylinders #5 and #2.
8. Rotate the engine crankshaft another 120 and repeat steps 3 through
5 to cylinders #3 and #4.
9. Install all cylinder rocker arms (intake and exhausts) and retaining bridge. Make certain
that the push rods are properly seated to their respective rocker arm and lifter. Tighten
the respective cylinder bridge/rocker arm cap screws to 30 Nm (21 ft. lbs.) when each
cylinder piston is at top dead center (cylinder intake and exhaust valves are closed).
10. Install the engine cylinder head valve cover. Tighten the valve cover bolts to 10 Nm (85 in.
lbs.). Refer to the appropriate vehicle Service Manual for detailed assembly instructions.
DECARBONING COMBUSTION CHAMBER AND VALVES:
1. Start the vehicle engine and allow the engine to reach normal operating temperature.
2. Remove the air tube from the engine throttle body.
3. With the engine at idle, spray the entire contents of Mopar Combustion Chamber
Cleaner, p/n 04318001AB, directly into the throttle body. As the cleaner is being
ingested, allow the vehicle to "load up" with the cleaner to the point that the engine is
almost stalling out. Maintain this condition until all of the cleaner is used/ingested.
4. Stop the engine once the entire can of cleaner has been ingested.
5. Install the air tube to the throttle body.
6. With the hood closed and the vehicle parked inside the garage, allow the vehicle
engine to heat soak for two to three hours. This will ensure that the engine will
maintain its temperature and will allow proper solvent penetration.
7. After engine soak, start the engine and drive the vehicle until the engine is
has reached normal engine operating temperatures.
8. If the vehicle is equipped with an automatic transmission, place the gear
selector into "L" (low). If the vehicle is equipped with a manual transmission,
place the transmission into first gear.
9. In a safe vehicle operating location that will allow the vehicle to be driven safely and at
the posted speed limit, accelerate the vehicle until the engine reaches 4500 RPM.
10. Hold the engine speed at this RPM for 15 seconds.
11. Slow down and in a safe location pull to the side of the road. Allow
the engine to idle for five seconds.
12. Repeat steps 9 through 11 five more times.
13. With the vehicle at operating temperature and using any available Freeze
Frame data recorded when the misfire DTC occurred, verify that the
misfire condition has been corrected.
gensysmike is offline
post #18 of 20 Old 10-03-2010, 01:54 PM
gremlinsteve
just toss a can of berrymans fuel injector cleaner into the tank...that stuffs tha bomb!
gremlinsteve is offline
post #19 of 20 Old 04-12-2011, 10:15 AM
2to1 Jeep wins
2011 MK Compass
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
EQUIPMENT REQUIRED:
REPAIR PROCEDURE:
INSPECTION:
VALVE ROTATION:
So this does NOT apply to 2005? Anyone?
2to1 Jeep wins is offline
post #20 of 20 Old 12-08-2012, 08:40 AM
DirtRider1357
I know this is an old thread but I'm getting the p0301 on my 2005 Lj and my mechanic narrowed it down to a sticky lifter
87 YJ, 4.0L, 5speed......sold, 05 LJ Rubicon
"It'll buff out"
"If it moves and shouldn't, use Duct Tape & Zip Ties. If it doesn't move and should, use WD-40 & A hammer"
DirtRider1357 is offline
p0301 , p0300 , code , error , advice , tj , wrangler
My Codes P0300 P0306 Fixed Grandpa Jeeper TJ Wrangler Technical Forum 15 04-09-2015 08:21 PM
P0300, p0301, p0304 609Mudder89 TJ Wrangler Technical Forum 2 06-27-2010 12:52 PM
Codes p0301 p0304 ProjectWhiteTJ TJ Wrangler Technical Forum 56 10-05-2009 05:05 AM
Need diagnostic codes Help engine running like crap Bojeepus YJ Wrangler Technical Forum 8 08-21-2009 07:32 AM
Check Engine Light Codes P0300 & P0301 Ichabod1960 TJ Wrangler Technical Forum 5 12-31-2007 11:56 PM
