P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. - JeepForum.com
post #1 of 5 Old 12-26-2008, 08:51 AM Thread Starter
blackattak
OK this showed up this morning. Engine Light is on solid so I believe it is not a major issue. Very cold overnight & when I started up this morning (started easy enough) & it hesitated a bit when I pulled out of the driveway & on the street the warning light was on. Did the 3 key turn tricjk to get the code. What should I do about it? Anything to really worry about?
blackattak is offline
post #2 of 5 Old 12-26-2008, 09:10 AM
flatlander757
Not a huge deal. It's a post-cat O2 sensor so it is primarily there for keeping the catalytic converter in check, it also plays a part in the A/F ratio, but not to the extent that the pre-cat sensors do.
The heater element basically makes the sensor warm up faster to get you out of open loop(closed loop is more efficient). I can't remember how many O2 sensors are under a TJ in all, but if it's 4(as opposed to 2), then check your PDC as there should be an O2 sensor heater relay, which supplies the voltage to the 1/2 and 2/2 O2 sensors heater elements. The 1/1 and 2/1 sensors get it directly from the ASD(auto-shutdown) relay. All are PCM triggered, but I doubt the PCM could be the problem as it's only the 2/2 sensor throwing the code, I'm not positive but I believe both the post-cat O2 sensors are on the same circuit so aside from the O2 sensor itself going bad, it could be the wiring.
In a nutshell:
A) Check the O2 sensor wiring for any opens, shorts, etc anything visually wrong with it.
B) Replace the 2/2 O2 sensor(bank 2 sensor 2).
You may find your gas mileage takes a crap until it is fixed.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #3 of 5 Old 12-26-2008, 09:32 AM Thread Starter
blackattak
Only 25,000 km on it so I`ll let the dealership look after it on Monday.
post #4 of 5 Old 12-29-2008, 10:40 AM Thread Starter
blackattak
Would have taken it in today but now light has turned off. Won't worry about it for now. Turned on during cold snap, above freezing last 2 days & now off?
post #5 of 5 Old 02-28-2011, 04:20 PM
mynameislarry
i have the same problems man, did you do anything about it? or did the problem procede on cold days? im about to replace mine soon
mynameislarry is offline
O2 sensor heater circuit readiness test won't complete mobyjeep TJ Wrangler Technical Forum 28 07-02-2016 10:22 PM
does a 1991 wrangler yj have an o2 sensor heater? kornonthekob99 YJ Wrangler Technical Forum 0 11-28-2009 09:58 AM
CEL Code P0161 - which O2 sensor is it? el guapo TJ Wrangler Technical Forum 10 11-23-2009 08:15 AM
O2 Sensor Heater Pyrate TJ Wrangler Technical Forum 2 07-06-2007 03:12 PM
P0135; 02 Sensor Heater Malfunction, Sensor bad???? perley03 TJ Wrangler Technical Forum 5 01-18-2007 08:40 PM
