Oxygen Sensors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Oxygen Sensors
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-07-2006, 08:33 AM   #1
finsout
Oxygen Sensors
Are there really FOUR O2 sensors on an 01 wrangler 4.0?
finsout is offline   Reply With Quote
Unread 07-07-2006, 08:50 AM   #2
Shorty
Not 100% sure but my 01 grand cheerokee has 4 I think there are 2 before the cat and 2 behind or something.
Who lives in a pineapple under the sea?
"Horrendously scratched black jeep club member #7"
(w/ Hurculined accents)
Shorty is offline   Reply With Quote
Unread 07-07-2006, 09:53 AM   #3
JFM626
I think on an 01 there is only 1. You can check by crawling underneath and looking where the header comes off the engine. If you have cats there, you will see two large bulges. There will also ge an o2 sensor just down stream on one of them. There is also a cat just before the muffler. I think the most you can have is three, not four in any event.
JFM626 is offline   Reply With Quote
Unread 07-07-2006, 10:00 AM   #4
finsout
i got the error p152 on the check engine light which indicates that sensor 2/1 (second front i believe) has high voltage. would you recommend replacing just that one or all?
Unread 07-07-2006, 10:11 AM   #5
digitalcox
digitalcox's Avatar
Not sure on an '01 but I know for sure there are four of them on my '04.
Have a good one,
Justin
digitalcox is offline   Reply With Quote
