oxygen sensor question.. - JeepForum.com
post #1 of 16 Old 04-20-2009, 12:10 PM Thread Starter
gene97sport
alright.. my 97 from what i was told has a 98 ZJ grand cherokee 4.0 engine . now the part number for both models are different. should i go ahead with a ZJ oxygen sensor? would the plug fit? http://www.quadratec.com/products/52449_0286.htm or order a 97 TJ sensor which is a different part number. also.. are the computers the same for the both? if not, should it have one from a ZJ? thanks getting terrible mileage
gene97sport is offline
post #2 of 16 Old 04-20-2009, 12:14 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
All your wiring harness should still be TJ, so you would need a TJ 02 sensor.
If you can post a picture, this can be verified. Post a picture under the hood and another showing the upstream 02 sensor.
Wheelin98TJ is offline
post #3 of 16 Old 04-20-2009, 12:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the engine swap was done correctly all the necessary TJ parts and engine accesories were installed on the ZJ block. Your Jeep, and your computer, don't know and can't tell the difference what block is installed. Order the correct parts for the make, model and year of Jeep you own.
I would buy an O2 sensor from a local parts store so I can compare the sensor and plug before I buy it.
You may even find that more than one model of Jeep uses the exact same O2 sensors.
CJ7-Tim is offline
post #4 of 16 Old 04-20-2009, 12:33 PM Thread Starter
gene97sport
post #5 of 16 Old 04-20-2009, 12:43 PM Thread Starter
gene97sport
just took the pics. right now it has the 97 TJ bosch sensor with the plug. reading up that bosch isn't the way to go and with the error code 21 i'm getting
(Upstream oxygen sensor response slower than minimum required switching frequency. Upstream oxygen sensor heating element circuit malfunction. Downstream oxygen sensor heating element circuit malfunction. Downstream oxygen sensor input voltage maintained above the normal operating range. Oxygen sensor voltage too low, tested after cold start. (Upstream or Downstream) Left oxygen sensor input voltage maintained above the normal operating temperature.)
should i replaced both up and downstream sensors?
makes sense
post #6 of 16 Old 04-20-2009, 01:31 PM
Wheelin98TJ
JEEP FREAK
I would just do the upstream sensor.
I would also consider replacing your down pipe.
An easy way to do this is with a new cat, such as a high flow cat from Mangaflow. They sell a direct fit cat converter with pipe all the way to the header for around $100.
Someone replaced part of your down pipe and did a hack job. The 90 degree bend is killing your exhaust flow.
post #7 of 16 Old 04-20-2009, 02:11 PM Thread Starter
gene97sport
i'll look into that right now! yea that 90 degree bend just didnt look right lol thanks for the help. if anyone has some links is to where to buy.. i'll try the google/ebay route.
post #8 of 16 Old 04-20-2009, 02:16 PM
Wheelin98TJ
JEEP FREAK
Here is a link to the Magnaflow converter I was referring to:
http://www.quadratec.com/products/51410_101_07.htm
post #9 of 16 Old 04-20-2009, 02:22 PM
Wheelin98TJ
JEEP FREAK
And I would get the 02 sensor from the dealer.
You can negotiate with them on their prices. If you can get it down to 10% over cost, you're doing good.
post #10 of 16 Old 04-20-2009, 02:38 PM
jgorm
jgorm's Avatar
www.rockauto.com has great prices on oem stuff.
jgorm is offline
post #11 of 16 Old 04-20-2009, 02:40 PM Thread Starter
gene97sport
yea, i was planning on getting the O2 sensor from the dealer. now the downpipe is included right? cause it only says Parts Included * Catalytic Converter on the quadratec site http://www.quadratec.com/products/51410_101_07.htm
post #12 of 16 Old 04-20-2009, 02:44 PM Thread Starter
gene97sport
yea, they have good prices
post #13 of 16 Old 04-20-2009, 03:15 PM
jgorm
jgorm's Avatar
from RA on my mustang forums for more discount.
Just enter discount code: C0B2B01F848C in the “How Did You Hear About Us?” line of your shopping cart. This code expires 4/23/2009.
with o2 sensors ALWAYS use the OEM version. I can't even count how many people i know that have had issues with knock off o2 sensors.
jgorm is offline
post #14 of 16 Old 04-20-2009, 04:01 PM Thread Starter
gene97sport
http://www.quadratec.com/products/55120_10.htm
http://www.quadratec.com/products/55120_09.htm
quadratec has 2 type of sensors for the 97-00 model. are these OEM?
post #15 of 16 Old 04-20-2009, 05:58 PM Thread Starter
gene97sport
ok ordered oem sensors and the magnaflow setup
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 7 03-18-2009 06:38 AM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 0 03-17-2009 06:35 PM
Oxygen Sensor question Grape Ape YJ Wrangler Technical Forum 3 02-22-2007 08:30 PM
