Oxygen Sensor Problem / Question - JeepForum.com
post #1 of 1 Old 03-17-2009, 07:35 PM Thread Starter
jeep11484
2014 JK Wrangler
Okay, so i bought an 01 Wrangler on Saturday. It was just too good of a deal for me to pass up (especially since it was garage kept and never off road). I started it up today and my check engine light came on.
So i did the key trick and pulled the following codes: P0136, P0141, P0161.
I did use the search function and i found out what the problem(s) should be. It appears that it was oxygen sensor(s).
According to the info on JF i needed to replace the oxygen sensor downstream on the front and rear manifold. Hopefully that makes sense.
So i ran down to Advance Auto since they are right around the corner and tried to get the parts i needed to try and fix it tonight.
So they didn't have all the parts i neede. They had the front one which is Bosch part #13687 but not the rear one part #13691. According to them #13691 is discontinued and they cannot get it.
So i looked on the internet to see what i could find. I found a site that said they had them so i added it to the cart and proceeded to checkout. Once i did it actually changed the part number to #13867 and beside it put (13691). So the question i have is will part number #13687 work for both my needs or am i missing something. I pulled them both off to look at them and they look the same to me but want someone elses expert opinion since i am no expert. Thanks
jeep11484 is offline
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 05:20 PM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 02:29 PM
oxygen sensor question.. gene97sport TJ Wrangler Technical Forum 15 04-22-2009 05:55 PM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 7 03-18-2009 07:38 AM
Oxygen Sensor question Grape Ape YJ Wrangler Technical Forum 3 02-22-2007 09:30 PM
