Oxygen Sensor Problem / Question - JeepForum.com
post #1 of 8 Old 03-17-2009, 06:24 PM Thread Starter
jeep11484
2014 JK Wrangler
Okay, i just bought an 01 Wrangler on Saturday. It was just too good of a deal to pass up and is in exceptional condition (since it's never been off road and garage kept). I started it today and my check engine light came on. I did the key trick and the codes that pulled up in the dash were P0136, P0141 and P0161.
I did all the searches and found a lot of info that helped me with the original problem. From what I gathered it is a problem with my Oxygen sensor(s). It looks like I need to replace both of the oxygen sensors downstream on the front and rear of the manifold. Hopefully that makes sense.
So once i figured that out i went to Advance Auto since they are right down the street from to see if they have the parts i need. It looks like i need Bosch part #13687 and part #13691. I can get the first part easy but the second one is supposedly discontinued according to Advance.
So i decided to look online to see what i came up with. I searched and found a site that supposedly has it but once i put it in my cart it actually changes the part number to #13687.
So the question i have is are part #13687 and #13691 interchangeable? I pulled the connectors apart tonight and they look the same, so am i missing something or am i just an idiot?
jeep11484 is offline
post #2 of 8 Old 03-17-2009, 06:41 PM Thread Starter
jeep11484
2014 JK Wrangler
this is a double post. My computer froze on the original so i started over but it actually posted both. Please delete this one. Thx
post #3 of 8 Old 03-17-2009, 07:12 PM
txflood3
I have an '01 and just ran through a ton of trouble with my O2 sensors....here is what I learned....
Bosch sensors are hit or miss....they may work, they may not
I was buying the universal plugs so I spliced the wires together
I did buy 1 plug and play and worked ok
the consensus on these boards is don't waste your money with Bosch
spend the extra $20 and get the right one from Jeep and change it once....just make sure you know the ones you need...each one has a different price at Jeep
txflood3 is offline
post #4 of 8 Old 03-17-2009, 07:16 PM Thread Starter
jeep11484
2014 JK Wrangler
Yeah i was gonna call the Jeep dealership tomorrow and see what i could get. I didn't want to go the route of buying universals just b/c it takes longer and i have heard they are not as durable as the direct fit type. Hopefully i can get this figured out so i can get back on the road trouble free.
post #5 of 8 Old 03-17-2009, 07:31 PM
bandofjeepsys
Definitely stay away from Bosch sensors. Check out www.oxygensensors.com. I have not had any problems with the Denso or Walker sensors. Make sure and get that sensor socket too!
bandofjeepsys is offline
post #6 of 8 Old 03-17-2009, 07:33 PM
txflood3
everyone has their opinions on tools and how it made a task easier.....I just used an open end wrench...no problems at all
txflood3 is offline
post #7 of 8 Old 03-17-2009, 07:39 PM Thread Starter
jeep11484
2014 JK Wrangler
They seem to be priced right thats for sure! Thanks for the info. What is so bad about Bosch? It was actually recommended from the post i read.
post #8 of 8 Old 03-18-2009, 06:38 AM
timmytimm3
Tech Tip- Use penatrating fluid before even trying to break them free. If you are really straining, heat up the threads on the manifold with a torch. Be patient and don't strip them out. Mine were a real ***** to get out! I also applied never seize to the new threads.
timmytimm3 is offline
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
oxygen sensor question.. gene97sport TJ Wrangler Technical Forum 15 04-22-2009 04:55 PM
Oxygen Sensor Problem / Question jeep11484 TJ Wrangler Technical Forum 0 03-17-2009 06:35 PM
Oxygen Sensor question Grape Ape YJ Wrangler Technical Forum 3 02-22-2007 08:30 PM
