Oxygen Sensor keeps going bad - JeepForum.com
post #1 of 13 Old 07-26-2010, 07:35 PM Thread Starter
Big_Daddy_75
I have a 1997 TJ 2.5L 5 speed with 174,000 miles on it. I have now gone through 2 oxygen sensors since I have owned it (3 years 1500 miles). The last one lasted about 300 miles and now I am getting a code and the jeep is running rich again. The last owner drive it a while with it like with it running rich. I knew this and when I checked the jeep out I saw a broken wire on the sensor. Replace it for the first time. I am not losing coolant and my engine temp is good. I have no white smoke and oil looked fine last change.
Any ideas why they the o2 sensor keeps going bad?
Thanks for the help and I would not have been able to lift my jeep without this forum. THANKS!
1997 TJ Wrangler w/ 174,000 miles - 4" Rough Country Series II - 285/70/17 BFG AT KO - 17" Cragar Soft 8's
Big_Daddy_75 is offline
post #2 of 13 Old 07-26-2010, 08:42 PM
cj847
What code are you getting? How are you determining the sensor is bad?
If you have a rich condition, I doubt the O2 sensor is bad.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #3 of 13 Old 07-26-2010, 08:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Is there any chance the 02 sensors have gotten any whiffs of silicone caulking? An 02 sensor can die quickly if it gets around any fresh uncured silicone glue or caulking.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #4 of 13 Old 07-26-2010, 09:18 PM Thread Starter
Big_Daddy_75
This is the key code I am getting. Code 51 A lean air/fuel mixture has been indicated by an abnormally rich correction factor. I will take it to an Autozone to have it read in the next few days.
I almost sure they have not touch any silicone.
post #5 of 13 Old 07-26-2010, 09:26 PM
Jerry Bransford
Administrator
It doesn't need to touch it, an 02 sensor just needs a good strong whiff of silicone to go bad.
Getting
post #6 of 13 Old 07-27-2010, 06:59 AM Thread Starter
Big_Daddy_75
I don't think there has been silicone anywhere near the sensor. This last one went right in from the box.
post #7 of 13 Old 07-27-2010, 07:40 AM
Sundowner
What brand of sensors are they?
Sundowner is offline
post #8 of 13 Old 07-27-2010, 10:10 AM
ElementX
Since you mentioned the original wiring being broken, maybe the wiring got corroded and high resistance is burning them out, or you have bare wire somewhere shorting. Any exhaust leaks? Specifically at the header bolts or cat?
'98 TJ Sport
ElementX is offline
post #9 of 13 Old 07-27-2010, 10:42 AM Thread Starter
Big_Daddy_75
The first was a Bosch and the one I just put in was a NKG.
The wire that was broken was right at the end of the sensor but I will take a closer look.
post #10 of 13 Old 07-27-2010, 06:28 PM
cj847
Out of the several hundred OBD II codes that may be set, not one of them is "O2 sensor bad". Since you just replaced it, I would not assume it bad again.
Sure, your O2 sensor may be bad, but my suggestion is you fix your wiring problem, or your vacuum leak, or leaky fuel injector, or incorrect fuel pressure.
PS> The lean/rich codes are two trip codes. So, if you reset the code and make a trip without of CEL it doesn't mean you fixed it yet. You need to take a few individual trips without a CEL to confirm.
Good luck with it. That code is sometimes hard to properly diagnose and fix.
cj847 is offline
post #11 of 13 Old 08-25-2010, 05:14 PM
scottbr
2016 JK Wrangler
It's not that I don't believe you Jerry, but HUH?
scottbr is offline
post #12 of 13 Old 08-25-2010, 06:31 PM
Jerry Bransford
Administrator
Oxygen sensor service | Motor | Find Articles at BNET
Oxygen Sensor Information
Pin down cause of oxygen-sensor alerts Ventura County Star
Defective Sensors Emit Black Smoke from Engines
Smoke a telltale sign of trouble - Sowetan LIVE
Getting
post #13 of 13 Old 08-25-2010, 07:15 PM
scottbr
2016 JK Wrangler
Ya learn something new every day. Thanks!
scottbr is offline
o2 sensor , bad , failing , tj , wrangler , exhaust , oxygen sensor
o2 senser chucksworth YJ Wrangler Technical Forum 8 05-23-2009 12:40 AM
How do you know O2 senser is bad? Tenn.Red TJ Wrangler Technical Forum 10 11-28-2008 07:18 PM
Cranshaft Position senser JeepYJ187 YJ Wrangler Technical Forum 1 11-20-2008 08:21 PM
o2 senser litel dart YJ Wrangler Technical Forum 4 11-08-2007 06:04 PM
Temp Guage Senser lucaswhunter YJ Wrangler Technical Forum 5 02-15-2005 07:05 PM
