oxygen sensor information needed - JeepForum.com
post #1 of 4 Old 01-11-2008, 10:25 AM Thread Starter
mmtphoto
seems like all my 'drivers' are either in need of or due to get new O2 sensors, and my 98 tj with a 4.0 is getting there (92,000) sooooo....
what is considered "original equipment" (brand)-I did look from up top, it looks like it only has one upstream-is that correct? (It's raining here, did not want Chinese water torture to see if that is correct).
I have my winter tires on now (almost new 31 x10.5 all terrain T/A) and my gas mileage is pretty bad-like, 12 or 13 mpg. If you factor that these are taller tires, and much heavier than the 235-70's that I run in the summer, it's reasonable to think I'm getting closer to 14-15, and I guess this vehicle is used more on short trips, around town-I figure, new O2 sensor cannot hurt, anybody know where the correct one (with the connector attached, don't really want to go the splice and soder route) can be had? thanks
mmtphoto is offline
post #2 of 4 Old 01-11-2008, 10:56 AM
Metzgerhund
Metzgerhund's Avatar
Your 98 has 2 sensors. One upstream on the exhaust manifold and one on the catalytic converter. The one upstream is for air/fuel ratio and the one on the cat. is for exhaust emissions. When I took off my Borla Cat-back and put on a Kolak exhaust I replaced my upstream sensor. Nothing was wrong with it but my Jeep has a little over 100,000 miles on it so I wanted to replace it anyway. The senor on my cat I'm not really concerned about. You can bypass these anyways so what's the point. I need it for inspection and that's it. So if this one needs replaced I'll wait till I get the CEL for it.
RED Jeep Club Member #444
Metzgerhund is offline
post #3 of 4 Old 01-11-2008, 11:29 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Correct, there's only 1 upstream sensor on your model year TJ.
I'm not sure who makes the OE part, but I do know its about $80 from the dealer.
I recommend the dealer part. You can get an aftermarket sensor that will plug right in for $20-30 cheaper, but they typically do not last as long.
Wheelin98TJ is offline
post #4 of 4 Old 01-11-2008, 02:16 PM
Nonya
I replaced mine today with a Denso,cost was 52 dollars.I hope it helps increase my fuel mileage.The factory O2 had 170k miles on it and still seemed to work ok.I figured i'd give it try to see if it really makes any difference in fuel mileage.It seems to run the same so i'd have to say the factory O2 is good for a very long time.The factory O2 didn't have a brand name on it i could find,only a part number.
Nonya is offline
Oxygen 02 Sensor FAQ and Information Alexia TJ Wrangler Technical Forum 117 10-05-2015 08:19 AM
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
Oxygen sensor jappe TJ Wrangler Technical Forum 8 09-06-2009 09:40 PM
New oxygen sensor help 92yjwrangler YJ Wrangler Technical Forum 15 08-11-2009 09:56 PM
