Oxygen Sensor - JeepForum.com
post #1 of 4 Old 07-27-2010, 03:17 PM Thread Starter
Fajitafred
Oxygen Sensor
Hello,
I am new to the Jeep Forum, so forgive me if this question has been answered somewhere on the site. I have my 97 Wrangler 4.0 and the other day after a hot hour and half drive my check engine light came on. I went to a local parts store and had them see what it was. The code turns out to be P0138, and the print out said, heated oxygen sensor bank 1 sensor 2. From what I've heard this something that a novice repairman like myself can do. However, I know that there are more than one sensor on my car. So my question is based of the information I provided, which sensor is it? I found one that is right after the catalytic converter, is this the one? Also if it is, do I have to remove the skid plate that is near it or can I just get to the sensor without removing it?
Thanks in advance for any help.
Fajitafred is offline
post #2 of 4 Old 07-27-2010, 03:24 PM
Sundowner
"Sensor 2" is the rear-most sensor...the one after the cat. However, I'd suggest that you do a couple of things before you buy a new sensor. First, check the fuses and relays under the hood...if the fuse is blown, then the P0138 code will be thrown. If the fuse is good, then crawl under the Jeep and start checking the connector and wiring for signs of damage. Both of these checks will take you no longer than five minutes, and that's if you don't know where to look. If you cannot find any sort of simple cause for the heater circuit to be out, then go ahead and swap the O2 sensor. For that, I suggest Liquid Wrench, an O2 sensor socket and an impact gun...you'll avoid most of the hassle with that combination.
Welcome to JF!
Sundowner is offline
post #3 of 4 Old 07-27-2010, 03:56 PM
Zen
AMEN!
Welcome to JF!
On an older vehicle I spray the threads of the O2 sensor multiple times over several days before attempting the swap. I don't use an impact wrench though, and sometimes depending on where the sensor is an open ended or box end wrench works better.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #4 of 4 Old 07-27-2010, 04:48 PM
Sundowner
This is excellent advice. When I checked mine not long ago, they just backed right on out with no effort whatsoever...but that's decidedly not the norm. I did, however, do exactly as Zen described...started soaking them about three days ahead of time.
I've found that the impact tends to take rusted stuff off quicker with less collateral damage...but a box-end and enough BFH will approximate an impact any day of the week!
oxygen sensor , p0138
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 05:20 PM
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 05:22 AM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 02:29 PM
Oxygen sensor? Smash209 YJ Wrangler Technical Forum 4 03-15-2007 09:20 PM
Oxygen Sensor championofblue TJ Wrangler Technical Forum 25 02-09-2005 09:37 PM
