Oxygen 02 Sensor FAQ and Information - Page 5 - JeepForum.com
 1Likes
post #61 of 118 Old 05-03-2012, 03:21 PM
chebbyfan
Originally Posted by purplepig View Post
The box says NTK, but it is made by NGK so same difference.
Ok thanks. Yes this forum is very helpful.
chebbyfan is offline
post #62 of 118 Old 07-21-2012, 05:17 AM
TNJeeeper
Originally Posted by nmj48 View Post
there you go
Why are there 2 "before" and 2 "after" numbers? Being new to changing O2 sensors, it's confusing to me. I'm looking to change the Bank 2 sensor 1, and want a MOPAR sensor. Which number is the correct part number? And am I correct in that this is the sensor that is just before the CC? Thanks.
TNJeeeper is offline
post #63 of 118 Old 07-21-2012, 05:48 AM
bonza
the two sensors "before" are both sensors #1, but bank one sensor differs from bank two due to the length of the pigtail, hence seperate part numbers
sensors #2 are both "after" and perform a different function to the "before" sensors and also have a different pigtail on each bank, again hence the reason for different part numbers.
look at the first post and it nominates the Mopar number for the model year and sensor you are after. also, Mopar sensors are supplied by NTK
"I like a man who grins when he fights"
— Winston Churchill..
bonza is offline
post #64 of 118 Old 07-21-2012, 06:27 AM
TNJeeeper
I don't see a part number for MOPAR for bank 2 sensor 1 on 2006 Rubicon. The info I see is as follows:
Upstream, Rear Manifold - Bank Two, Sensor One
ODBII Codes: P0151, P0152, P0153, P0154, P0155
Physically located towards the rear of the vehicle before the mini-catalytic converter.
~Parts~
Bosch
2000: Part #13280
2001-2003: Part #13664
2004: Part #15504
2005-2006: Part #13869
MOPAR
2000: Part #56041 213AF
2001: Part #56041 944AA
2002-2003: Part #56031 110AA
2004: Part #56028 994AA
There's no MOPAR part number for 2006 Rubicon, or any Wrangler.
post #65 of 118 Old 07-21-2012, 07:29 AM
BamaFanInTX
~Parts~
Bosch
2000: Part #13280
2004: Part #15504
MOPAR
Here is what I did last week when I was buying O2 sensors.
Go to Rock Auto
Get the part number:
NTK Part # 23160 Wire length: 11.80"
Upstream Rear; 2; 4; NTK is the OE Mfg
Search the web with that part number for the best deal. I ended up going with advanced because they had a coupon for $10 off orders over $30 and you can do in-store pickup. So i was able to go up there and get it right after I placed the order. coupon code: RETMENOT123
BamaFanInTX is offline
post #66 of 118 Old 07-21-2012, 09:25 AM
TNJeeeper
Is the "upstream rear; 2; 4; NTK" the same as Bank 2 Sensor 1?
post #67 of 118 Old 07-21-2012, 09:57 AM
DanZ51
That would be correct.
Front cylinders 1,2,3 = Bank 1.
Rear cylinders 4,5,6, = Bank 2.
Before PreCat Converter = Sensor 1.
After PreCat Converter = Sensor 2.
"I will always be an American Soldier"
DanZ51 is offline
post #68 of 118 Old 07-21-2012, 11:53 AM
TNJeeeper
Thank you, sir, for your help.
post #69 of 118 Old 07-21-2012, 12:15 PM
TNJeeeper
Go to Rock Auto
I was going to order from Advance using your code...store near me doesn't accept online orders. However, he took my order, ordered the part, and gave me the discount anyway. Thanks for the code and your help!!
post #70 of 118 Old 10-27-2012, 11:29 AM
Zetto
Zetto's Avatar
The last couple of weeks I keep receiving a P0431 CEL. I only get the light on warmer Southern California days. It only appears after driving the car for a few minutes and then coming to a stop (Stoplight, parking lot, etc...). I inspected and can not find any exhaust leaks. I had a friends shop run it on their smog machine and it passed with flying colors so I believe the catalytic converter is working properly (When I researched P0431 here everyone said it was a bad cat but the smog results seem to say otherwise).
Next up I was going to try replacing the bank 2 downstream and maybe the upstream O2 sensor unless anyone else has a suggestion?
06 Silver LJ
Savvy 4" lift with aluminum CA -- Currie AntiRock (Front) -- Currie F/R Trackbars -- Savvy Modular Under Armor
BF Goodrich T/A KO 285/75/16 on 16" Moab powdercoated black -- Vanco 16" big brake kit
JeeperMan swing-away tire carrier with tub extensions (JSPUex)
Four X Doctor Rocker Guards
Hella E-Code Housings -- ARB H4 Headlight Harness (M002) -- KC 130 watt SlimLite mounted on windshield
Zetto is offline
post #71 of 118 Old 02-17-2013, 10:31 PM
Zetto
Zetto's Avatar
Update for anyone else that experiences this. In December I dropped the exhaust to replace the oil pan seal (I thought it was the rear main seal leaking) and confirmed one of the pre-cats was broken up and clogged. I moved to Denver in January and the local dealer replaced the cats on the 80 year / 80K Federal Emissions Warranty.
Now that I have new catalytic converters I am wondering if I should replace any of the O2 sensors? I was putting up with P0431 for at least 20K miles over 4-6 months and I am wondering if the engine compensated and damaged any of the O2 sensors?
06 Silver LJ
Zetto is offline
post #72 of 118 Old 02-02-2014, 02:29 PM
bossind
Originally Posted by tiger-bailey View Post
Here are the 2005/2006 Mopar part numbers:
before - 56028995AB
before - 56028994AB
after - 56029049AA
after - 56029050AA
Can someone tell me which one is Bank 1 for P2096 on my 2005TJ, I've reached the end of the internet and I'm still not sure.
bossind is offline
post #73 of 118 Old 02-02-2014, 04:43 PM
bonza
O2 sensor closest to radiator and downstream of the mini cat. Mopar number 56029049AA
NGK 23159
http://www.jeepforum.com/forum/attac...1&d=1391384723
GottaSki likes this.
bonza is offline
post #74 of 118 Old 02-02-2014, 06:43 PM
bossind
NGK 23159
Nice!!!!
bossind is offline
post #75 of 118 Old 02-13-2015, 12:06 PM
GAYeep
Need help on NTK oxygen sensor part number for 06 Rubicon. Bank 1/Sensor 1 (Front Upstream) - I got NTK part number from NAPA as 23019. I notice forum says 23018. Which is it?
GAYeep is offline
2/2 Sensor Slow Response(Oxygen Sensor code P0159) Erik T. TJ Wrangler Technical Forum 9 10-03-2012 04:01 PM
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 04:20 PM
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 04:22 AM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 01:29 PM
oxygen sensor information needed mmtphoto TJ Wrangler Technical Forum 3 01-11-2008 02:16 PM
