Oxygen 02 Sensor FAQ and Information - Page 4 - JeepForum.com
post #46 of 118 Old 11-13-2011, 08:09 PM
crsifers
Originally Posted by bonza
does any one know what size socket to use?
Mine was 22mm
"My name is Alice, and I remember everything." - Alice (Resident Evil)
crsifers is offline
post #47 of 118 Old 11-14-2011, 01:39 AM
oakmckinley
For what it's worth my 2000 4.0 has just 2 sensors (no mini cats), and I used Bosch and they've been fine.
$0.02
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #48 of 118 Old 12-22-2011, 11:35 AM
rockspyder
$0.02
Glad I read this post. How long have your Bosch sensors been in?
I just replaced the exhaust system on my '97TJ, from (cracked but welded) header all the way back to the exhaust tip. We put the original sensors (yes, nearly 15 years old and never had a problem) back in, and two trips later they started throwing codes.
First time it happened I got a P0135P and a P0138 (no P). The MIL had lit just after it ran a little rough. BTW, what does that second P mean in the "P0135P"?
Reset the codes (with code reader).
I checked the codes again this morning after coming in to work, because I got a rough run pulling out after the engine had been running about 2 or 3 minutes. No MIL light, but I checked anyway, and got a P0138P.
Anyway, I've got the 1/1 and 1/2 Bosch sensors but haven't installed them yet -- although now I'm wondering if I need to check the part numbers against this thread before I try to install them. Or even trade them in on a different brand, although after reading this last post, I probably won't unless the part numbers are wrong.
I was hoping it would sort itself out after the "newness" of the pipes burned off, but I'm guessing that isn't going to be the case.
rockspyder is offline
post #49 of 118 Old 12-22-2011, 07:55 PM
luisi
Got my sensors replaced but the found out exhaust manifold is cracked so if im gunna redo my exhaust sys what would be most cost effective?
luisi is offline
post #50 of 118 Old 12-22-2011, 08:02 PM
rockspyder
I welded up my header for the short term. Much easier. I know I'll have to replace it sooner than later, but with financial commitments lately, I decided to take a chance on it if it only last a few months.
post #51 of 118 Old 12-23-2011, 09:19 AM
crsifers
I've had my Bosch in for about 2 months. No problems yet (as I knock on wood).
Sent from my T-Mobile G2 using JeepForum
crsifers is offline
post #52 of 118 Old 01-02-2012, 09:42 PM
Saisling
I replaced both my "pre" sensors with Bosch as they were only $19 a piece at the local NAPA and needed to get through emissions. Installation took all of about 10 minutes. Drove to Emissions station the next day, passed, then an hour later the rear sensor started throwing a code again. ...So not even 24hours on that Bosch one. So far, the front Bosch sensor hasn't thrown another code. That was... er.... 4-6 months ago I need to replace that Bosch sensor, but I just haven't bothered to do it yet.
Saisling is offline
post #53 of 118 Old 01-16-2012, 07:34 PM
MsGTI
Thank you for this thread..this morning as I was starting my Jeep up the check engine light came on.
It was very cold this morning and I haven't driven it since Friday.
Code P0132 came up after I did the *wiggle-key-thingy-3x*
I just replaced the 02 sensors last Thanksgiving at the dealership (code P0156).
Very informative and now I know where all these sensors are,thanks to the diagram
"Everyone has a plan until they are punched in the face."~Mike Tyson
2006 Jeep Wrangler TJ Metallic Khaki
2009 VW GTI
MsGTI is offline
post #54 of 118 Old 02-21-2012, 07:12 PM
purplepig
I am pretty sure I only have 2 also. I want to order from RockAuto. Do I go with the part numbers for 99's? The numbers are different.
purplepig is offline
post #55 of 118 Old 02-21-2012, 09:52 PM
26679cj5
2000 was the cross over year on the sensors and emissions system. Earlier 2000's had the 2 sensor system, later 2000's had the california emissions which is 4 sensors.
26679cj5 is offline
post #56 of 118 Old 02-22-2012, 06:42 AM
purplepig
^^^ so what year do I go with for the sensors? They are only $39 from RockAuto compared to almost $100 at the dealership.
post #57 of 118 Old 02-22-2012, 10:09 AM
26679cj5
if you go to advance auto parts website and search for oxygen sensors for your 2000 tj, you'll see that they have four parts listed for NTK's. Two of them will say california emissions and two of them won't be.
26679cj5 is offline
post #58 of 118 Old 02-22-2012, 10:33 AM
purplepig
Thanks 26679cj5 . I guess the ones that say "exc. Calif" are what I need.
I don't have any codes, but my gas mileage has gone done and I can't find any other issues. At 120K miles I am assuming it is time. How necessary is replacing the post cat sensor? I was only planning on replacing the pre-cat one.
post #59 of 118 Old 05-03-2012, 04:07 PM
chebbyfan
Originally Posted by Pillswoj View Post
Napa carries the NTK's which were OEM in the TJ.
Is it N "T" K or N "G" K? My NAPA says its NGK that they have and it even lists it as the OE sensor.
chebbyfan is offline
post #60 of 118 Old 05-03-2012, 04:17 PM
purplepig
The box says NTK, but it is made by NGK so same difference.
2/2 Sensor Slow Response(Oxygen Sensor code P0159) Erik T. TJ Wrangler Technical Forum 9 10-03-2012 05:01 PM
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction. blackattak TJ Wrangler Technical Forum 4 02-28-2011 05:20 PM
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 05:22 AM
Bank 2, Sensor 2 oxygen sensor... Alexia TJ Wrangler Technical Forum 2 09-19-2009 02:29 PM
oxygen sensor information needed mmtphoto TJ Wrangler Technical Forum 3 01-11-2008 03:16 PM
