OX Lockers - JeepForum.com
post #1 of 15 Old 02-23-2009, 10:10 PM Thread Starter
Tredloc
OX Lockers
I am looking to put OX lockers that fit my 2006 TJ and also upgrade with Chromoly axels. Everything is stock as far as the drive train, with the exception of 33 wheels, 3.5 lift kit, slip yoke, drive shaft,and gear ratio at 4.10. I have heard horror stories regarding the retainer clips breaking, but will lockers tend to add insult to injury, or are there other options without swapping out everything and going complete Dana 44 with OX?
No intent of going rock crawling, just want that extra when I need it. Snow and Sand is of the occasional trips, mostly trail trips.
Tredloc is offline
post #2 of 15 Old 02-24-2009, 02:06 PM
Border Dave
Got Sand?
Border Dave's Avatar
You don't list it on your profile, but by the way you said, "or are there other options without swapping out everything and going complete Dana 44 with OX?", makes me believe that you have a Dana 35 rear axle. Just by switching to chromoly axles, you won't eliminate the other Dana 35 weakness, the spider gears. Unless you plan on going to a Superior Super 35 Kit, I wouldn't put a locker in a Dana 35.
If you're only going to be wheeling in sand and snow, a locker might not be of very much benefit to you anyway, as long as all of your tires keep in contact with the ground. I think you might be better off just making sure to air down your tires and get either a Currie Antirock Swaybar or ORO SwayLoc.
David
My favorite shops in the Northwest:
Border Dave is offline
post #3 of 15 Old 02-24-2009, 04:08 PM
shawn1980
but if he put's in an ox locker there is no more spider gears. i have ox front and rear and love them. i also have alloy usa 30 spline shafts in the rear. it's nice to know if you need them you have em flip a lever and go imo.
green jeep club member #122
shawn1980 is offline
post #4 of 15 Old 02-24-2009, 06:41 PM
Tinker
Tinker's Avatar
Originally Posted by shawn1980 View Post
but if he put's in an ox locker there is no more weak spider gears. i have ox front and rear and love them. i also have alloy usa 30 spline shafts in the rear. it's nice to know if you need them you have em flip a lever and go imo.
Gotta agree with this. oh and X2 ^^
"Does this look broken to you?"
Tinker is offline
post #5 of 15 Old 02-24-2009, 07:15 PM
fratis
fratis's Avatar
a locked axle can help allot in sand. if you have a bit of a side-hill the uphill tire will look like its spinning but it wont be pulling/pushing the vehicle its rotation will only keep up with the others. had a situation where a lockerless friend was drifting sideways into the ocean. the slope was minimal but the front end had a hard time keeping it pointed in the right direction. others with lockers had no problem. our "sand" is very course shell material that has allot of air in it and is very deep.
fratis is offline
post #6 of 15 Old 02-24-2009, 07:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Locking your front Dana 30 is a lot different than locking his rear Dana 35c which is simply not strong enough for a locker. Your front Dana 30 will survive being locked, his rear Dana 35c will not. Why? Because the front axle seldom sees more than about 50% of the torque that the rear axle commonly sees.
A stock Dana 35c rear axle should never be locked. It can be upgraded so it can survive being locked but stock, it's not up to being locked. Really.
Getting
Jerry Bransford is offline
post #7 of 15 Old 02-24-2009, 07:20 PM
never monday
the clips don't fail.
The shaft fails. A regular 27 spline D35 haft necks down from 1.3" to 1.15". Where the transition is is where it fails.
If your going with an OX, get the 30 spline version and the cromo shafts to go with it. you'll have no problems then.
never monday is offline
post #8 of 15 Old 02-24-2009, 07:23 PM
RogueSpear2023
Selectable lockers are great even in snow, most people don't like auto lockers on snow and ice because they lock when ever they have power so they tend to push out to a fish tale. With selectables like a an OX this is eliminated. Lockers are great in deep snow, off road. Lockers lead opens follow in deep snow wheeling. But as far as your rear axle to put an OX locker in it you are going to have to get a super 35 kit with and OX locker which they do make now. A stock D35 won't take a locker, even with chromemoly shafts, you could do it with a c-clip elminator kit, and a locker.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #9 of 15 Old 02-25-2009, 09:26 AM
shawn1980
I understand that jerry. that is why I stated that I upgraded the rear to alloy USA shafts
post #10 of 15 Old 02-25-2009, 10:06 AM
dbno123
dbno123's Avatar
I have OX lockers front and rear (D30 & D35) with stock 27 spline axles and i've never had a problem. I love them and I would definitally recomend them to anyone. I do some hard wheeling but its mud or dirt. I dont do any rock crawling. Everybody has there own opinion but with my experiance there great!
dbno123 is offline
post #11 of 15 Old 02-25-2009, 10:11 AM
0II0
KF4VGI
0II0's Avatar
I have an Ox in the rear 35 as well. But do it right and go with the s35 with 30 spline alloy shafts. Otherwise you will be wondering if it will hold everytime you pull the lever to engage.
NC2001TJ
0II0 is offline
post #12 of 15 Old 02-25-2009, 04:43 PM Thread Starter
Tredloc
Thanx All, looks like a Superior S35 w/C cip eliminator and alloy shafts are the ticket. Will most likely add alloy up front and OX F&R. Appreciate the info.
Tredloc is offline
post #13 of 15 Old 02-25-2009, 06:01 PM
shawn1980
you will love that setup imo.
post #14 of 15 Old 02-25-2009, 06:03 PM
never monday
that's a solid combo
post #15 of 15 Old 02-25-2009, 06:07 PM
rickm8
:] glad to see people getting resolutions on here haha
99 TJ Sport 4.0, 5 spd, 2" BB, 31" BFG a/t ko's
BLACK JEEP SOCIETY #362
rickm8 is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 05:37 PM
Lockers provinT13 YJ Wrangler Technical Forum 6 06-02-2008 08:29 AM
Lockers hillbillybob TJ Wrangler Technical Forum 9 03-01-2007 09:00 AM
Air Lockers TSEJEEPERS YJ Wrangler Technical Forum 3 02-15-2005 05:29 AM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 03:45 PM
