Quantcast OX Locker in D35c - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > OX Locker in D35c
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 08-01-2008, 02:53 PM   #1
0II0
KF4VGI
0II0's Avatar
OX Locker in D35c
Anyone here running an OX in a D35c? What are the known problems. I have heard that the square block in the middle of the OX that holds the Cclips is prone to breaking. Any info would be great.
Thanks
NC2001TJ
0II0 is offline   Reply With Quote
Old 08-01-2008, 03:02 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Avoid installing any kind of a locker into a Dana 35c axle which simply is not strong enough to withstand the doubled stress a locker causes. The weakness is not in the c-clip area, the weakest points that cause the most problems are the axleshafts themselves. They tend to snap in half, allowing the wheel and broken half of the axleshaft to slide out of the housing.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 08-01-2008, 03:20 PM   #3
never monday
Jerry,
We'll hope he's talking about the 30 spline OX for the D35. If he's talking about installing an OX and not upgrading shafts. I can only warn DON'T
Get Savvy
never monday is offline   Reply With Quote
Old 08-01-2008, 03:58 PM   #4
Benderff
intentionally left blank
Benderff's Avatar
They make an OX for the 35? Why?
Benderff is offline   Reply With Quote
Old 08-01-2008, 04:21 PM   #5
HipCheck_1
They make a 27 spline version for the Dana 35.
Maybe with stock size tires and chromoly 27 spline axles, but I wouldn't trust it...
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline   Reply With Quote
Old 08-01-2008, 05:46 PM   #6
kizer
I know two guys that both run OX's without any issues. Of course they know the rear is waiting to explode, but as well drive responsibly enough.
The only problem either have had is adjusting the cable, which isn't hard once you tinker with it.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
kizer is offline   Reply With Quote
Old 08-01-2008, 06:56 PM   #7
IslandTJ
Drink Oregon Craft Beer!
IslandTJ's Avatar
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Any automatic locker would mate well with a 30 spline Super or Grande kit. 27 splined shafts are best kept to limited slips on 31" tires, while 32-33" tires are somewhat safer with 27 splined chromoly shafts.
1998 TJ Moss Green Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Old 08-01-2008, 08:21 PM   #8
kenbuck
While the d35 in the TJ is a c-clip type, i dont believe it is the D35c. The D35c is used in the WJ and the "C" doesnt stand for c-clip.. FYI
02 TJ.
2.5" RC Progressive Lift
1" PA Body Lift
33" KM's
misc other stuff.....
kenbuck is offline   Reply With Quote
Old 08-01-2008, 08:37 PM   #9
Michael_K
I have S35 with Ox locker.
As far as the cable adjustment wise, I have no idea why people say it is hard to adjust. It is more of a hassle than hard to do. I found my sweet spot as stated in the manual and it worked out at the first try.
I installed mine; dropped the cover about 4+ times, I didn't have to re-adjust the cable at all.
One issue I had was the sticky cable 4wd.com sent me which OX picked up to warranty it. I am not sure whose fault it really is, but the replacement cable OX sent me fixed the problem with the locker disengaging after locking.
Another thing is, the Diff. cover is thick and heavy with not so flexible cable attached to one end of it, makes it quite a hassle maneuver the cover into place. But that will be a one time deal when you are installing.
Just be careful routing the cable for the rear locker, as you can fry it with the exhaust.
Here is my shifter mounting location.
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline   Reply With Quote
Old 08-01-2008, 08:52 PM   #10
Rafikie
I'm also running an OX with my 35 although I did upgrade the axles to the 30spline setup. I've had zero issues. Absolutely love them
97 TJ 4.0, AX15, Back halfing w/ tons and 4?s
Stop by and check us out Western Mass 4x4 or Check us out on Facebook and be sure to stop by and like the NEA4WDC while your there.
Rafikie is offline   Reply With Quote
Old 08-01-2008, 10:18 PM   #11
elkfan2
elkfan2's Avatar
the dana 35c that is used in the tj is the same dana 35c that is used in the wj.
elkfan2 is offline   Reply With Quote
Old 08-01-2008, 11:28 PM   #12
kenbuck
not it is not at all. the wj dana 35c is actually a dana 35c model 198, it is wider than a tj d35 and the axles have a different bolt pattern, 5x5". the castings are different too, with the wj having a flat top on the casting for the upper a-arm mount as it doesnt have 2 rear upper control arms like a tj does.
02 TJ.
1" PA Body Lift
33" KM's
Old 08-02-2008, 12:09 AM   #13
elkfan2
elkfan2's Avatar
but it's still a dana 35.
Old 08-02-2008, 05:03 AM   #14
kenbuck
The Dana 35c in the WJ doesnt use c-clips, the one in the TJ does. Just like the D44 used under the WJ is different than the D44 used under the TJ. Just because they share the same axle designation doesnt make them the same.
02 TJ.
1" PA Body Lift
33" KM's
Old 08-02-2008, 08:09 AM   #15
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The TJ D35 is a D35c.
The WJ D35 is also a D35c, and yes, it is different than the TJ D35.
C stands for custom meaning it was assembled at the Jeep factory, not by Dana.
I'm not sure how this is relevant to the thread, but hopefully this clears up the confusion.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Glock Forum
