Oversize Tires and Stock Jack - JeepForum.com
post #1 of 13 Old 03-17-2012, 01:52 PM Thread Starter
Rick_Fury
How big of a tire can I go before the stock jack becomes useless?
I am thinking about a set of 32" tires, and was wondering if I need to buy a bigger jack to change the tire.
Rick_Fury is offline
post #2 of 13 Old 03-17-2012, 01:55 PM
biffgnar
biffgnar's Avatar
Stock jack will work fine with 32s
Romney in 2020!
biffgnar is offline
post #3 of 13 Old 03-17-2012, 02:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
In fact, the stock jack works fine with 35" tires and 37" in a pinch.
The below shows the stock jack lifting my axle with its 35" tires.
Don't forget, a 32" tire only lifts the axle 1" higher than a 30" tire does.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #4 of 13 Old 03-17-2012, 02:29 PM
danielbuck
1946 CJ2
Indeed, that little bottle jack works quite well
danielbuck is offline
post #5 of 13 Old 03-17-2012, 02:37 PM Thread Starter
Rick_Fury
GREAT! Thank you gentlemen!
Will someone please comment on my other post? I am looking to buy a replacement exhaust manifold to replace my current cracked Borla header:
http://www.jeepforum.com/forum/f9/re...ifold-1344229/
post #6 of 13 Old 03-17-2012, 02:40 PM
222Doc
222Doc's Avatar
I also pack some wood. a 4x6 about a foot long and 4 2x4's, just if needed.
222Doc is offline
post #7 of 13 Old 03-17-2012, 03:06 PM
biffgnar
biffgnar's Avatar
Originally Posted by 222doc View Post
i also pack some wood.
tmi
Romney in 2020!
biffgnar is offline
post #8 of 13 Old 03-17-2012, 03:41 PM
chebbyfan
chebbyfan is offline
post #9 of 13 Old 03-17-2012, 05:43 PM
Heath
2014 JK Wrangler
tmi
No doubt
2013 JKU Rubicon
Heath is offline
post #10 of 13 Old 03-17-2012, 06:08 PM
jeepinjeffrey
Yea the stock bottle jack is pretty great!
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #11 of 13 Old 03-17-2012, 06:23 PM
danielbuck
1946 CJ2
out of curiosity, has anyone tried hooking up a drill to operate the jack? Not really for the actual jacking, but for getting the jack extended and then collapsed again for storrage? rather than sitting there spinning it with your fingers, I bet a small electric hand-drill would work great!
post #12 of 13 Old 03-17-2012, 06:27 PM
jeepinjeffrey
Haha with like a big flat head bit. Might work! Never thought of that.
2003 Wrangler Sport
post #13 of 13 Old 03-17-2012, 08:28 PM
biffgnar
biffgnar's Avatar
Here's a pretty cool jack that's made to run with a drill: http://www.pirate4x4.com/forum/showthread.php?t=1049558
Romney in 2020!
biffgnar is offline
Oversize spare on a stock carrier? SBLax101 TJ Wrangler Technical Forum 9 07-09-2011 11:18 PM
Auto tranny with stock gears and oversize tires mightydog78 TJ Wrangler Technical Forum 7 02-25-2010 10:06 PM
Stock jack and 35" tires Jeep4VA TJ Wrangler Technical Forum 34 11-30-2006 11:13 AM
How often to rotate oversize tires? Cycline3 TJ Wrangler Technical Forum 14 03-16-2006 08:14 PM
Oversize tires on stock tailgate Jeepin' Rock Cl TJ Wrangler Technical Forum 4 07-06-2005 10:59 AM
